Best way to restore taillight lenses. #1438369
05/18/13 04:52 PM
05/18/13 04:52 PM
Delta BC, Canada
Baller Offline OP
Baller  Offline OP
Delta BC, Canada
What is the best way to remove haze from the red plastic lenses? Tried the search function on this site with no results and I would rather hear from someone on this site rather than some google search result. Thanks.
1970 GTX, work in progress...
Re: Best way to restore taillight lenses. [Re: Baller] #1438370
05/18/13 05:00 PM
05/18/13 05:00 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Did mine with a buffing wheel, and compound I believe I got from Eastwood...
Re: Best way to restore taillight lenses. [Re: RSNOMO] #1438371
05/18/13 06:18 PM
05/18/13 06:18 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Mothers Mag & Aluminum Polish...
Re: Best way to restore taillight lenses. [Re: 1_WILD_RT] #1438372
05/18/13 06:30 PM
05/18/13 06:30 PM
Delta BC, Canada
Baller Offline OP
Baller  Offline OP
Delta BC, Canada
Wow, looks awesome. Never used that stuff before. What was your application to get these results?
Re: Best way to restore taillight lenses. [Re: Baller] #1438373
05/18/13 11:35 PM
05/18/13 11:35 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You can also glass bead them and have them clear coated.
Master, again and still
Re: Best way to restore taillight lenses. [Re: Baller] #1438374
05/19/13 12:16 AM
05/19/13 12:16 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You can get allot of improvement just by rubbing the Mothers on the lenses with a soft cloth but I was dealing with some pretty serious scratches so I actually sanded the lenses with 800 grit then polished with Mothers & a buffer....
Re: Best way to restore taillight lenses. [Re: 1_WILD_RT] #1438375
05/19/13 12:17 AM
05/19/13 12:17 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And.. If Domingo happens to chime in he really did an outstanding job on some 70 Challenger lenses... They look better than NOS...
Re: Best way to restore taillight lenses. [Re: 1_WILD_RT] #1438376
05/19/13 09:18 AM
05/19/13 09:18 AM
What did you do about the area that has the raise letters/numbers?
Re: Best way to restore taillight lenses. [Re: ] #1438377
05/19/13 12:08 PM
05/19/13 12:08 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You avoid sanding there & polish it with the Mothers as best you can....
Re: Best way to restore taillight lenses. [Re: 1_WILD_RT] #1438378
05/21/13 11:39 AM
05/21/13 11:39 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Other route is Mcguires Plastic Cleaner and then Polish. It works great and is made for this !!!
Re: Best way to restore taillight lenses. [Re: ] #1438379
05/21/13 10:35 PM
05/21/13 10:35 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
If it's not a points car you can just sand them off and be done with it.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Best way to restore taillight lenses. [Re: a12rag] #1438380
05/21/13 10:37 PM
05/21/13 10:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Meguiars has allot of decent products, their Plastic Cleaner #17 & Polish #18 aren't among them...
Re: Best way to restore taillight lenses. [Re: 1_WILD_RT] #1438381
06/02/13 10:45 PM
06/02/13 10:45 PM
Delta BC, Canada
Baller Offline OP
Baller  Offline OP
Delta BC, Canada
The Mothers worked great. Even used it on the reverse lenses which were heavily oxidized and coated in black soot. Did it all by hand as the lenses were not too badly scratched. Thanks again Randy.
