42's finally.... #1438303
05/18/13 02:16 PM
05/18/13 02:16 PM
Chilliwack B.C. Canada
RUNCHARGER Offline OP
My son finally got the missing link for his 87 "Ramcharger" a roll cage is next on the list..
Sheldon
Re: 42's finally.... [Re: RUNCHARGER] #1438304
05/18/13 02:17 PM
05/18/13 02:17 PM
Big improvement and he can use those 4.88's now.
Sheldon
Re: 42's finally.... [Re: RUNCHARGER] #1438305
05/18/13 02:20 PM
05/18/13 02:20 PM
He also bought a NP203 that will get turned into a doubler so that will make low, low range 4.1 rather than 2.1. The tires took up a bit of space hauling them home in his "small" truck.
Sheldon
Re: 42's finally.... [Re: RUNCHARGER] #1438306
05/18/13 02:35 PM
05/18/13 02:35 PM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Beast!!!
Re: 42's finally.... [Re: RUNCHARGER] #1438307
05/18/13 02:37 PM
05/18/13 02:37 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Nice. I found a set of 16.5x9.75 Steelies object Craigslist and when I went to get them they had some very useable 14x36.5 tires on them. I was rather delighted for $50
Re: 42's finally.... [Re: 76dodgeboy] #1438308
05/18/13 02:47 PM
05/18/13 02:47 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
4.88s and 37" tires is the same as 4.10s and 31s That's my plan
42s and 4.88s is same as 4.10s and 35s. He might want 5.13s. This is all calculated using Ramchargercentrals calculator
Re: 42's finally.... [Re: 76dodgeboy] #1438309
05/18/13 03:16 PM
05/18/13 03:16 PM
Good score Dodgeboy: He is going to put a high stall convertor in when he finally swaps in the big block. It should work okay especially with the doubler. I'm amazed it did so well with the 125HP 318 with the 37's on it.
Sheldon
Re: 42's finally.... [Re: RUNCHARGER] #1438310
05/18/13 04:09 PM
05/18/13 04:09 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I wasnt thinking about the doubler setup . Forget my last post than
I thought $50 for the rims alone was good. Than I saw the tires that he claimed junk do to weather cracks. He only sent pic of rims not panned out far enough to see tires. Inside I was like Theyll be offroad use only for mine or the wifes truck. Not sure yet. Still have alot to do to them before even driveable. Both get D60s Front and rear. Hers will get 4" suspension and probable a 3" body and its already a 400 truck so Ill just swap in a Known to run motor. Mine will be 6" suspension with a 440/4spd when done. Both are Clebcab Shortboxes to boot. Getting a better cab for hers as there is rust above the driver door inside do to a mouse nest most likely. I plan to reuse her cab though. Im going to make my std cab lb plow truck a clubcab shortbox. Might get the last set of D60s I have too.
Ive followed some of your sons build on RCC. Seems like a Heck of a kid
Re: 42's finally.... [Re: 76dodgeboy] #1438311
05/18/13 05:14 PM
05/18/13 05:14 PM
He's done well. Too bad location is everything, I junked out the rustfree clubcab from the 78 due to no one in this area wanting it. I hate wasting such nice parts but what can you do? I would have gladly given it away to someone that would have used it.
Sheldon
Re: 42's finally.... [Re: RUNCHARGER] #1438312
05/19/13 08:02 AM
05/19/13 08:02 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Sweet! What's the purpose of those bars looped up on the front bumper? I see them alot and most have tow straps wrapped around them.
Re: 42's finally.... [Re: 76dodgeboy] #1438313
05/19/13 08:28 AM
05/19/13 08:28 AM
southeast, mich
MachoMan Offline
MachoMan  Offline
southeast, mich
LOVE steelies
Please register your Dodge truck here 1972-1980 Dodge truck registry
Re: 42's finally.... [Re: MachoMan] #1438314
05/19/13 09:47 AM
05/19/13 09:47 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Looks like a beast!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 42's finally.... [Re: redraptor] #1438315
05/19/13 10:45 AM
05/19/13 10:45 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Their called stingers. They are to help get on a pile of rocks.
Re: 42's finally.... [Re: RUNCHARGER] #1438316
05/19/13 11:29 AM
05/19/13 11:29 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
Sheldon he most likely will have rear drive shaft issues. He may have to get a rear cv style made up
Re: 42's finally.... [Re: NITROUSN] #1438317
05/19/13 12:50 PM
05/19/13 12:50 PM
Pete: Yep, we've been talking about that. We do know where there is a SB frame so he might lengthen it a few inches. It would help the front DS though except a longer front DS would hit the skid plate so that would have to be re-engineered as well. He's learned a lot on this thing and it's nice to see him think everything through and execute it.
The SB frame is thicker than a Ramcharger frame as well, so it would be stronger but might twist less, everything's a tradeoff.
Sheldon
Re: 42's finally.... [Re: 76dodgeboy] #1438318
05/19/13 01:13 PM
05/19/13 01:13 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Also, they can prevent flipping forward if you get into trouble.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: 42's finally.... [Re: RUNCHARGER] #1438319
05/19/13 01:52 PM
05/19/13 01:52 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I've always heard RC frames were thicker that's why they are good for Cummins swaps
No need for a new frame. Time to upgrade to 4-links
Re: 42's finally.... [Re: DusterDave] #1438320
05/21/13 05:00 PM
05/21/13 05:00 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
