8 3/4 rear end date codes and Identification #1437096
05/15/13 08:58 PM
05/15/13 08:58 PM
Chicago Blackhawks
hemicar1971 Offline OP
Chicago Blackhawks
Looking for a web site that tells were the date codes are on an 8 3/4 rear end. I am talking about from the first year to the last year of the 8 3/4.
1971 HEMI E BODY REGISTRY
Re: 8 3/4 rear end date codes and Identification [Re: hemicar1971] #1437097
05/16/13 12:18 PM
05/16/13 12:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Date codes I think are on the Chuck only , never seen one on a housing .
Re: 8 3/4 rear end date codes and Identification [Re: hemicar1971] #1437098
05/16/13 01:37 PM
05/16/13 01:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're looking for something like the BOM stamps on the Dana 60, you won't find it on the 8 3/4". Externally, the casting date on the third member and internally the date stamped on the ring gear is all there is.
Re: 8 3/4 rear end date codes and Identification [Re: hemicar1971] #1437099
05/16/13 04:16 PM
05/16/13 04:16 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
489 case 3.23 open diff. - 1969 Charger early July SBD
ps, there is black paint on the bottom of the case ( seen in the picture ) and what I think was either white or pink paint mark towards the ft , it was real faint so I can't say with 100% certainty which color
Re: 8 3/4 rear end date codes and Identification [Re: gtx6970] #1437100
05/16/13 09:35 PM
05/16/13 09:35 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
489 case 3.23 open diff - 1969 Coronet early Nov SPD. Very similar
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 8 3/4 rear end date codes and Identification [Re: 69CoronetRT] #1437101
05/17/13 02:21 AM
05/17/13 02:21 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
69 Barracuda 3.23 w/o Sure Grip, dated 10/23 for early November SPD. Among other things, had the blue paint daub shown on the bottom of the case and the yellow circle on the housing at bottom left of photo.
Re: 8 3/4 rear end date codes and Identification [Re: JohnRR] #1437102
05/17/13 11:09 AM
05/17/13 11:09 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: 8 3/4 rear end date codes and Identification [Re: 1_WILD_RT] #1437103
05/17/13 02:07 PM
05/17/13 02:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There's always one in the crowd.
I unfortunately don't get the chance to part out pristine rust free cars :whining:
Re: 8 3/4 rear end date codes and Identification [Re: JohnRR] #1437104
05/17/13 09:04 PM
05/17/13 09:04 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
John, I suggest you move.... Yeah out here we are lucky & find markings that in many areas are lost forever..
FWIW there is a date code & an axle assy number... And on this particular vehicle the axle was assembled one day after the third member was assembled...
Re: 8 3/4 rear end date codes and Identification [Re: kentj340] #1437105
05/17/13 09:14 PM
05/17/13 09:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The paint blotches on the underside of the carrier (black, blue, pink, etc.) were put on to indicate which gear package it had, ratio, etc.
