Page 1 of 3 1 2 3
Carter 500's, can this mess be fixed & if so worth it? #1437014
05/15/13 08:19 PM
05/15/13 08:19 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Pulled them out of storage last year, pulled the top off and found this mess. They had been sitting for a decade and had been fine when pulled off the car.
Units are 4758S and 4761S 500's and worked fabulous on my 440.
I had one of two plans- Take these two, strip them down to the bare castings and load glass bead into the sandblast cabinet and see how they clean up. $100 worth of kits and floats and let'er rip.
Or just simply purchase a pair of reman Edelbrocks 500 or 600 cfm from Summit and call it a day.
Thoughts?
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: gdonovan] #1437015
05/15/13 08:20 PM
05/15/13 08:20 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Second pic.
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: gdonovan] #1437016
05/15/13 09:01 PM
05/15/13 09:01 PM
Thoughts?
Soak em in the bucket of carb soup for several days then bristle brush & see what you get.
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: gdonovan] #1437017
05/15/13 09:05 PM
05/15/13 09:05 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Maybe just look around at swap meets, etc for a better couple if you don't want to go to the expense of new?
I just picked up a 9500 Carter on Sunday in a package deal with a 9625, an intake, etc. at a swap meet.
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: OzHemi] #1437018
05/15/13 09:09 PM
05/15/13 09:09 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
ask Scott Harms see what he thinks. Probally has same carbs
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: OzHemi] #1437019
05/16/13 06:32 AM
05/16/13 06:32 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
I'm working under time constraints so waiting for a GOOD pair to show up at a swap meet isn't an option. $250 a pop at Summit is not terrible, but I'd rather put that money towards rims.
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: gdonovan] #1437020
05/16/13 07:00 AM
05/16/13 07:00 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Glass bead them, they'll look next to new, a couple carb kits and they'll run great. Dave
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: quickd100] #1437021
05/16/13 08:40 AM
05/16/13 08:40 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Glass beaded the original carb off of my 67 R/T.. Came out great.. Should say this was after trying soda blasting, and walnut shells.. they didn't work, at least not in the cabinet blaster...
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: floridian] #1437022
05/16/13 12:26 PM
05/16/13 12:26 PM
dogdays Offline
dogdays  Offline
What you're showing isn't that bad, it'll clean up with some carb cleaner in a bucket and a little time spent with a brass bristle wire brush.
Someday I need to post a picture of a 4966 I bought that "needs rebuilding".
R.
Heck, I'll pay shipping if you want to mail them to me!
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: dogdays] #1437023
05/16/13 12:55 PM
05/16/13 12:55 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I can restore those to look and run as good as new, no problem.
*I just recieved these original 409 carbs in to restore, definately one of the more challenging projects I've taken on but believe it or not I've brought worse ones back from the dead, yours would be a walk in the park by comparisons!
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: ScottSmith_Harms] #1437024
05/16/13 01:00 PM
05/16/13 01:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think that's an option at this point?
What's the time from you getting one to shipping it back out? Say something like a new unused Thunder carb to make it look like an original carb ?
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: JohnRR] #1437025
05/16/13 01:12 PM
05/16/13 01:12 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Hi John, my lead time varies based on my work load, I'm generally 6-8 weeks out. I can sometimes do better if there's a rush job but that's on a case by case basis. As far as your Thunder carb body refinishing request goes, that's a process I use when building my Hemi clones but that's not a service I offer on its own.
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: ScottSmith_Harms] #1437026
05/16/13 01:29 PM
05/16/13 01:29 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
If I was doing a restoration Scott you would be the first man I'd call but a restoration isn't required for this little operation ;-)
I'm just looking to put the dual quads back on the GTX, nothing special required. Either I'll get these working or just pop for a pair of remans and sell these off as cores (with full disclosure) to offset some of the cost.
Going to pickup 50 pounds of glass bead from Tractor Supply tonight and see how it goes, nothing to lose. Nothing is bound up, just corrosion in the bowls. The outside of the carbs look better than the insides!
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: gdonovan] #1437027
05/16/13 01:52 PM
05/16/13 01:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No problem brudda! Just letting you know those are savable. I could use the cores if you end up getting rid of them.
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: gdonovan] #1437028
05/16/13 01:58 PM
05/16/13 01:58 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
When you're done glass beading,make sure you get "ALL" the glass out of everywhere,you will have a nightmare if you don't !
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: 62maxwgn] #1437029
05/16/13 09:22 PM
05/16/13 09:22 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Oh ya- Soaked in a 5 gallon pail of soap and water, rinsed, blown out, agitated in the bucket again and a final rinse followed with a good carb clean blasting.
The worse one cleaned up nice, one primary jet is being stubborn though. I'm letting it sit overnight soaking in liquid wrench. I might leave it alone since it ran well or I might bang an extractor in the jet and dig it out. I don't like the idea of having one stuck in there.
I didn't get crazy cleaning certain areas since they are just cosmetic interior areas and I wanted to limit the time the unit was in the cabinet.
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: gdonovan] #1437030
05/16/13 09:23 PM
05/16/13 09:23 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
One more
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: gdonovan] #1437031
05/17/13 12:34 AM
05/17/13 12:34 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Looking good, those should cleaned up great! ........Look what I'm facing this evening
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: ScottSmith_Harms] #1437032
05/17/13 12:35 AM
05/17/13 12:35 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
At least I got a free Mud Dauber nest with them
Re: Carter 500's, can this mess be fixed & if so worth it? [Re: ScottSmith_Harms] #1437033
05/17/13 12:36 AM
05/17/13 12:36 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
And the owner "Helped" me get the throttle shafts free......By bending the blades in half with a screw driver.......
Page 1 of 3 1 2 3
