Sunoco 94 jetting/report and % ethanol test #1436832
05/15/13 01:31 PM
05/15/13 01:31 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
unscientific jet test below!
Does anyone have back to back runs and dyno info on E fuel blends verses non blends and do the E10 blends like Sunoco 94 like more jet and timing!!
did some searches but did not find exactly what I was looking for but maybe now guys have more experience??
Re: Sunoco 94 E10 jetting [Re: Dodgem] #1436833
05/15/13 01:38 PM
05/15/13 01:38 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Not sure about timing differences, but Keith Dunnuck's recent article in Mopar Muscle on air-fuel tuning w/ a wide-band O2 sensor leads me to believe the 10% ethanol blends make more power at WOT tuned for air-fuel ratios closer to 12.0 vs. 13.0 for non-blended gas.
Re: Sunoco 94 E10 jetting [Re: BradH] #1436834
05/15/13 02:37 PM
05/15/13 02:37 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
I'll have to go read it seems I get them (Mopar muscle) out of the mail box them and leave them in a pile??
wonder what jetting achieves this??
Re: Sunoco 94 E10 jetting [Re: Dodgem] #1436835
05/15/13 06:13 PM
05/15/13 06:13 PM
BradH Offline
BradH  Offline
The standard reply "It depends..." is the only true answer to that question.
Re: Sunoco 94 E10 jetting [Re: BradH] #1436836
05/15/13 06:34 PM
05/15/13 06:34 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
I more meant if X jetting in the test with 0 Ethanol and how much he ended up going in jets sizes with 10% as in 1 or 2 jet sizes in this case!
Re: Sunoco 94 E10 jetting [Re: BradH] #1436837
05/16/13 10:31 AM
05/16/13 10:31 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
read the article does not really tell what jet changes from a 0% ethanol fuel to a 10 % ethanol fuel??
Did find this on line that says:
"E-10 -lower float levels 1/32 from original specifications increase main metering circuits’ fuel flow by 10 percent, increase idle jet diameter by 0.002 inch."
so does that equates to about 3 jet sizes
supposedly According to Holley, each jets size is just over 3%
source
http://www.thecarburetorshop.com/Ethanoluse.htm
Re: Sunoco 94 E10 jetting/report [Re: Dodgem] #1436838
05/19/13 11:30 AM
05/19/13 11:30 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Well when we check my plugs two weeks ago they were real white and clean.
so when I went to jet up Friday I found I actually had the stock jets in (92 square) instead of the 94's I had run in the cold last fall forgot when after last time out i had ignition problem which turned out to be failing coil I had put the stock for my old dommy back in.
I wanted to go 95 square but only had 2 95's so i went 94/95 front and 95/94 back.
First 4 TT's for 1/8 mile pro tree racing going in much deeper than normal 1/8 mph were 102 into a cross wind where last week similar air were 101 ran clean and smooth plugs now have just a slight darkness to them so think I'm on the right track. Now to test the 94 I ran to see what the actual Ethanol % is?
Re: Sunoco 94 E10 jetting/report [Re: Dodgem] #1436839
05/19/13 05:56 PM
05/19/13 05:56 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
I just tested the fuel I bought Friday (and the past 3 weeks) and it is in fact 10% ethanol. Drained the fuel from the car and put it all in the truck as it's likely three weeks till I go out again.
Wonder if there is a two way spring loaded vent valve to keep it sealed from the air while it sits in the fuel cell??
Re: Sunoco 94 E10 jetting/report [Re: Dodgem] #1436840
05/19/13 06:17 PM
05/19/13 06:17 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Fuel safe looks like they have two way vent valve that takes low pressure each way to let pressure out or let air in when fuel pump reduces pressure
http://www.fuelsafe.com/store/vent-check-valves.html?mode=list
http://www.fuelsafe.com/store/vent-check-valves/tpv6-in-line-pressure-relief-vent-valve.html
Re: Sunoco 94 E10 jetting/report [Re: Dodgem] #1436841
05/19/13 06:31 PM
05/19/13 06:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In the heat you have to let it vent... you MIGHT be
able to find a 1 psi pop off valve so it will relieve
pressure above 1 psi... but I dont know of any
Re: Sunoco 94 E10 jetting/report [Re: MR_P_BODY] #1436842
05/19/13 07:18 PM
05/19/13 07:18 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
This one seems to be a low pressure two way .08 psi to suck in and .725 psi to vent out??
Re: Sunoco 94 E10 jetting/report [Re: Dodgem] #1436843
05/20/13 10:17 AM
05/20/13 10:17 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Probably not the best answer to your post, but there is a builder on here who is in Ontario like us (haven't seen him post in a while, unless im just not here enough anymore, goes by RAMM) and me and him discussed some stuff through pm's about octane and compression using our pump fuel. He said he made more power using shell 91 over sunoco 94, but I use the Sunoco stuff just because its more common here, and because I will take the extra octane rating for cheap insurance to avoid detonation on the street and WOT with my compression (10.5:1 with iron heads).
Re: Sunoco 94 E10 jetting/report [Re: mshred] #1436844
05/21/13 12:00 AM
05/21/13 12:00 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Funny you should mention that. :-0) part of what got me going was the 10% in the US threads and wondering if Sunoco is in fact 10% as I did find on line and verified with a test. Then how to take ethanol out of the gas for you lawn mowers (and snow blowers up hear) then my machinist was telling me about a roundy round guy we know running a 347 ford who made the most power on a dyno with Shell V91 even over 94 Sunoco (20 hp and 30 or some other fuel brands) just doing fuel changes and running again. I'm going to buy some shell 91 and test it for ethanol as looking for fuel for the lawn mower at the very least. But at 11.75 to 1 and maybe a true 12 to 1 with my aluminum rod growth hot not sure I want to try 91. If I do it will be a TT day and start my timing at say 34 and sneak it back up to 39??
Now on line searches dated 2012 turned up Esso 91 is supposed to be ethanol free, I seen a returned inquiry to sunoco (so Husky and Petro can) saying 91 is also ethanol free but only way to guaranty you get ethanol free is to buy from stations that don't sell ultra 94??
apparently 94 is 91 with 10% ethanol added which brings the octane from 91 to 94?? will be checking!
I think the shell is supposed to have some special New Nitrogen Enriched ??
Today I tested 87 from Petro canada and it's 8% Ethanol
Re: Sunoco 94 E10 jetting/report [Re: Dodgem] #1436845
05/21/13 12:10 AM
05/21/13 12:10 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I tested pump 93 from several different stations around me on my dyno.
They all were right around 6% ethanol which is required to get the tax breaks on ethanol fuel. Sunoco93 cost 20 to 30 horsepower compared to Citgo93 in my area on a 550 hp engine . I have tested it against other fuels available around here and Citgo consistently shows gains.
Again,this is whats available here and your results may vary.
Keith
Re: Sunoco 94 E10 jetting/report [Re: Dodgem] #1436846
05/21/13 12:12 AM
05/21/13 12:12 AM
Toronto
mshred Offline
mshred  Offline
Toronto
I tried finding the post on the OSCA message board, but I asked a question on there about gasoline, and Nick Agostino (im sure you know him, runs the twin turbo camaro now in outlaw 10.5) who builds gas stations had told me that all gasoline in Canada HAS to have 5% ethanol in it as legislated by the government. Now, I have never tested the gasoline from shell or esso, but if he is right (and id like to think he is since he builds the damn places) then I would assume those fuels contain ethanol as well, even if in smaller amounts.
Only way to find out though is to test like you are and see
Re: Sunoco 94 E10 jetting/report [Re: mshred] #1436847
05/21/13 12:25 AM
05/21/13 12:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your taking a number as GOD... as you said that the so
called 91 made more power... it may have on that
set up.. over octane WILL make less power per the
same timing.... its not rocket science but it does
take testing
Re: Sunoco 94 E10 jetting/report [Re: MR_P_BODY] #1436848
05/21/13 12:41 AM
05/21/13 12:41 AM
Toronto
mshred Offline
mshred  Offline
Toronto
take testing
Actually, I said that the only way to really know the ethanol levels and see which will make more power is through testing
I myself have personally never done any tests to see.
Re: Sunoco 94 E10 jetting/report [Re: mshred] #1436849
05/21/13 12:49 AM
05/21/13 12:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its always a bit scary to drop the octane but I've
done it on 2 engines and went quicker on the track
without issues... MOST people tend to over octane
to be safe and just call it good
Re: Sunoco 94 E10 jetting/report [Re: MR_P_BODY] #1436850
05/21/13 12:57 AM
05/21/13 12:57 AM
Toronto
mshred Offline
mshred  Offline
Toronto
I have always been the type of guy you mentioned in the latter...but this post has me thinking about possibly trying out the fuels back to back and seeing if there is a difference
Re: Sunoco 94 E10 jetting/report [Re: Dunnuck Racing] #1436851
05/21/13 02:25 PM
05/21/13 02:25 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Thanks keith like I said a freind who runs in the lower Nascar Canada ranks has tested and got best so far fom Shell V Power. supposed to be ethanol free.
Anyway the law As I understand it in ontario and I think canada right now is there has to be an average content of 5% ethanol in the total fuel sold by any one company.
Going out now to but some Shell V power and testing it for Ethanol and maybe some Esso 91 while I'm out!
