piston coatings , do it at home ??? #14337
02/15/05 04:56 PM
02/15/05 04:56 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
can i do it at home ? wheres dulcich ? i thought i saw a pick of his in the mag doing it in the kitchen ??? of course i won't do it while the wife is home
trying to salvage some slightly used parts for a bucks down rebuild ...
Re: piston coatings , do it at home ??? [Re: JohnRR] #14338
02/15/05 05:03 PM
02/15/05 05:03 PM
Cornfield. IN
Clair Offline
Pot Stirrer #4
Clair  Offline
Pot Stirrer #4
Cornfield. IN
This is the recipe my Grandpa told me about.
Give it a try.
½ cup of B32 flour
1/3 cup of used 10-40 Pennzoil
2 Red hen eggs
Combine ingredients and roll pistons in batter
Cook until a 12 pack is gone.
Re: piston coatings , do it at home ??? [Re: Clair] #14339
02/15/05 06:41 PM
02/15/05 06:41 PM
London, England
Gavin Offline
Gavin  Offline
London, England
I'm very interested in this - Dulcich seems to use them a lot and I intend to try at least some thermal barrier and possible friction reducer coatings. Not sure whether Steve did 'em himself or sent 'em out
One of those rare additions that increase efficiency with little downside other than the price!! Need to be using more modern technolgies like these.
Re: piston coatings , do it at home ??? [Re: JohnRR] #14340
02/15/05 06:43 PM
02/15/05 06:43 PM
A John there are a lots of uses for the kitchen range. However some of those coating can make the range or dishwasher unuseable for cooking or washing dishes. Please consider that first.
You might be able to pickup a range at Goodwill, Salvation Army etc on the cheap.
Max
Re: piston coatings , do it at home ??? [Re: JohnRR] #14341
02/15/05 07:23 PM
02/15/05 07:23 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Yes, you can do it at home if you have a sand blaster and air brush. Thermal and dry film coatings don't create enough stink to render an oven useless, but do create enough stink to know it isn't food sitting in there.
Techline Coatings sells films for home application. I've used their stuff ina couple of my rebuilds now. I'm sure there are others out there as well if you do a web search.
Re: piston coatings , do it at home ??? [Re: TC@HP2] #14342
02/15/05 08:25 PM
02/15/05 08:25 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Techline Coatings lots of good info
Re: piston coatings , do it at home ??? #14343
02/15/05 09:27 PM
02/15/05 09:27 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Max
max , i was joking about using the kitchen oven , though as soon as we get the new gas range the current electric is being relocated to the basement
thanks for the links , now i need to ge tan air brush .
didn't someone sell coated pistons ? speedomotive ??? not that i want to buy new slugs ...
Re: piston coatings , do it at home ??? [Re: JohnRR] #14344
02/15/05 10:01 PM
02/15/05 10:01 PM
JohnRR,
We use the coatings all the time in our shop.
Check out Techline Coatings.
They are very simple to use, and they do work!
We spray all our parts at the shop, and then I bring them home to bake them in the oven. The thermal barrier coatings, and anti-friction coatings DO NOT smell when you are baking them, so you don't have to worry about the wife complaining too much. We do the spraying at work, because that is where all the smell is, and we have a small spray booth there.
Try it, you won't be disappointed!
Ken
Re: piston coatings , do it at home ??? #14345
02/16/05 09:21 AM
02/16/05 09:21 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
Which coatings are best for piston tops, combustion chambers, valves, etc.?
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: piston coatings , do it at home ??? [Re: racealittle] #14346
02/16/05 11:13 AM
02/16/05 11:13 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Is spraying the pistons really worth the money?
Re: piston coatings , do it at home ??? [Re: Jeepmon] #14347
02/16/05 02:34 PM
02/16/05 02:34 PM
Iowa City, Iowa
joaks360 Offline
super gas
joaks360  Offline
super gas
Iowa City, Iowa
And I don't know about everyone else, but I would be a little leary of sandblasting my 500 dollar pistons...?
Slow '71 Demon W2 360 4-spd (in the works) Slower '92 Dakota Sport 3.9 (blown) Slowest '87 Dakota 3.9 (cute lil' p.o.s.) I know Jack.
Re: piston coatings , do it at home ??? [Re: JohnRR] #14348
02/16/05 08:02 PM
02/16/05 08:02 PM
Iowa City, Iowa
joaks360 Offline
super gas
joaks360  Offline
super gas
Iowa City, Iowa
Re: piston coatings , do it at home ??? [Re: joaks360] #14349
02/16/05 09:34 PM
02/16/05 09:34 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I too would really like to know what other people think about coating the pistons...
Not trying to hijack this thread but my pistons are out of the car and I can either a) do nothing, b) do the home coating or c) send them off to have them proffesionally coated..
What do you all think..
Re: piston coatings , do it at home ??? [Re: Jeepmon] #14350
02/17/05 09:19 AM
02/17/05 09:19 AM
Sparks,Nv.
P
pete Offline
super street
pete  Offline
super street
P
Sparks,Nv.
btt
Re: piston coatings , do it at home ??? [Re: pete] #14351
02/17/05 09:32 AM
02/17/05 09:32 AM
Pilot Mound, Iowa
N
Nobody Offline
super gas
Nobody  Offline
super gas
N
Pilot Mound, Iowa
Coat em with oil and shove em in
Nobody knows better.
Re: piston coatings , do it at home ??? [Re: Nobody] #14352
02/17/05 10:14 AM
02/17/05 10:14 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
It's like having too much ignition(or blocking the heat crossover) ..It will help you if you use it, but it's not necessarily a must have. They do reduce wear, extend life, and help keep the heat where it belongs, but they also cost a little for each application. Will you feel a boost? not like a cam swap, but you may notice less tendency to detonate.
Re: piston coatings , do it at home ??? [Re: moper] #14353
02/17/05 11:12 AM
02/17/05 11:12 AM
Southern Oklahoma
wildman340 Offline
wildman340  Offline
Southern Oklahoma
1974 Dodge Dart Sport 340 4 Spd Endless Project 1999 Ram 1500 CC 5.2 5 speed
Re: piston coatings , do it at home ??? [Re: racealittle] #14354
02/17/05 10:56 PM
02/17/05 10:56 PM
For the piston tops, and combustion chambers we use a product from Tech Line Coatings called CBC1.
CBC1 POWERKOTE (Cermet Coating Thermal barrier)
Part #3oz. 2213
Retail packaged version of CBC2/CBX
Designed for Performance engines.
Thermal barrier coating
Reduce part temperature.Keeps heat in combustion chamber longer through the power stroke
Increase torque and H.P. Increase combustion chamber efficiency
Reduce fuel consumption
Water based no hazardous fumes, non flammable
Requires baking. Cures at 300f for 1 hour. Must be oven cured
You do have to sandblast the piston tops, but this is very easy to do. Just mask off the skirts of the pistons, and sand blast the tops w/ new sand, w/ low pressure around 35lbs. Any machine shop should be able to do this for you relatively cheap.
For the skirts, we a product called DFL-1, also from Tech Line Coatings. This is basically the same stuff that Federal Mogul, and other piston manufacturers are now using on their new pistons.
DFL-1 POWERKOTE (Dry Film Lubricant)
Part #3 oz. 2107
High pressure lubricant
Reduces friction, galling and scuffing. Increases part life.
Requires no clearance changes to compensate for the coating.
Apply to any part subject to sliding or rotating friction .
Excellent for use on bearings .
Water based no hazardous fumes .
Requires baking.
Cures at 300f minimum. Must be oven cured
All coatings should be applied w/ either a small detail spray gun, or a hobby style airbrush.
Visit there website for more info.
There products work great.
Tech Line Coatings
Ken
Re: piston coatings , do it at home ??? #14355
02/17/05 11:19 PM
02/17/05 11:19 PM
Detroit, Michigan
fjr340gts Offline
fjr340gts  Offline
Detroit, Michigan
Or, just send them to Automotive Machine here in MI and they'll do it for you using TechLine coatings. Check below in my signature line. There is also a price list on their webpage.
Re: piston coatings , do it at home ??? #14356
02/19/05 12:04 PM
02/19/05 12:04 PM
racealittle Offline
racealittle  Offline
Thanks for the info CDPKen. I'll look into the product for my piston tops. I'm not sure about baking my new cylinder heads though.
