piston coatings , do it at home ???
#14337
02/15/05 04:56 PM
02/15/05 04:56 PM
Posts: 74,911 U.S.S.A.
JohnRR
U.S.S.A.
can i do it at home ? wheres dulcich ? i thought i saw a pick of his in the mag doing it in the kitchen ??? of course i won't do it while the wife is home
trying to salvage some slightly used parts for a bucks down rebuild ...
Re: piston coatings , do it at home ???
[Re: JohnRR]
#14338
02/15/05 05:03 PM
02/15/05 05:03 PM
Posts: 8,215 Cornfield. IN
Clair
Pot Stirrer #4
Pot Stirrer #4
Cornfield. IN
This is the recipe my Grandpa told me about. Give it a try. ½ cup of B32 flour 1/3 cup of used 10-40 Pennzoil 2 Red hen eggs Combine ingredients and roll pistons in batter Cook until a 12 pack is gone.
[Re: JohnRR]
#14340
02/15/05 06:43 PM
02/15/05 06:43 PM
A John there are a lots of uses for the kitchen range. However some of those coating can make the range or dishwasher unuseable for cooking or washing dishes. Please consider that first.
You might be able to pickup a range at Goodwill, Salvation Army etc on the cheap.
Max
[Re: JohnRR]
#14344
02/15/05 10:01 PM
02/15/05 10:01 PM
JohnRR,
We use the coatings all the time in our shop. Check out Techline Coatings. They are very simple to use, and they do work! We spray all our parts at the shop, and then I bring them home to bake them in the oven. The thermal barrier coatings, and anti-friction coatings DO NOT smell when you are baking them, so you don't have to worry about the wife complaining too much. We do the spraying at work, because that is where all the smell is, and we have a small spray booth there. Try it, you won't be disappointed!
Ken
#14345
02/16/05 09:21 AM
02/16/05 09:21 AM
Posts: 1,263 Southwestern Ontario Canada
racealittle
Which coatings are best for piston tops, combustion chambers, valves, etc.?
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: Nobody]
#14352
02/17/05 10:14 AM
02/17/05 10:14 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
It's like having too much ignition(or blocking the heat crossover) ..It will help you if you use it, but it's not necessarily a must have. They do reduce wear, extend life, and help keep the heat where it belongs, but they also cost a little for each application. Will you feel a boost? not like a cam swap, but you may notice less tendency to detonate.
[Re: racealittle]
#14354
02/17/05 10:56 PM
02/17/05 10:56 PM
For the piston tops, and combustion chambers we use a product from Tech Line Coatings called CBC1. CBC1 POWERKOTE (Cermet Coating Thermal barrier) Part #3oz. 2213 Retail packaged version of CBC2/CBX Designed for Performance engines. Thermal barrier coating Reduce part temperature.Keeps heat in combustion chamber longer through the power stroke Increase torque and H.P. Increase combustion chamber efficiency Reduce fuel consumption Water based no hazardous fumes, non flammable Requires baking. Cures at 300f for 1 hour. Must be oven cured You do have to sandblast the piston tops, but this is very easy to do. Just mask off the skirts of the pistons, and sand blast the tops w/ new sand, w/ low pressure around 35lbs. Any machine shop should be able to do this for you relatively cheap. For the skirts, we a product called DFL-1, also from Tech Line Coatings. This is basically the same stuff that Federal Mogul, and other piston manufacturers are now using on their new pistons. DFL-1 POWERKOTE (Dry Film Lubricant) Part #3 oz. 2107 High pressure lubricant Reduces friction, galling and scuffing. Increases part life. Requires no clearance changes to compensate for the coating. Apply to any part subject to sliding or rotating friction . Excellent for use on bearings . Water based no hazardous fumes . Requires baking. Cures at 300f minimum. Must be oven cured All coatings should be applied w/ either a small detail spray gun, or a hobby style airbrush. Visit there website for more info. There products work great. Tech Line Coatings Ken
#14356
02/19/05 12:04 PM
02/19/05 12:04 PM
racealittle
Thanks for the info CDPKen. I'll look into the product for my piston tops. I'm not sure about baking my new cylinder heads though.
