1970 challenger "lowering the front end" #1433697
05/09/13 06:49 PM
05/09/13 06:49 PM
United States
ssdodge70 Offline OP
United States
Is it necessary to realign the wheels if i want to lower the front end 1-2 inches?
Car is totally stock, just don't want to wreck the new tires..
Thanks..
Re: 1970 challenger "lowering the front end" [Re: ssdodge70] #1433698
05/09/13 06:53 PM
05/09/13 06:53 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Yes, changing ride height will require a re-alignment. It wont be off a ton but, still enough to cause wear.
Mopar to the bone!!!
Re: 1970 challenger "lowering the front end" [Re: ssdodge70] #1433699
05/12/13 11:51 AM
05/12/13 11:51 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
you dont want it to get it lower than where it was supposed to be from the factory. The suspension geometry is best at stock height,,,,just looseingng the torsion bars to get it lower will make things worse.
Re: 1970 challenger "lowering the front end" [Re: domingo] #1433700
05/12/13 01:29 PM
05/12/13 01:29 PM
Kirkland, Washington
Pacnorthcuda Offline
Come on guys! People have been lowering the ride height of Mopars below stock for decades without ill effects!
A drop of 1 inch isn't likely to cause tire wear issues, 2 inches is another matter. Consider this, STOCK alignment specs of these old cars were designed for bias ply tires and often called for slightly positive camber. Positive camber sucks. Lowering the front will change the camber towards the negative........l.that is a GOOD thing if the car is positive at stock height and on radial tires.
I would drop an inch, maybe even 1.5 below stock without giving it a second thought. If it keeps you up at night then get it re-aligned, but align it to "your" specs, not 40 year old factory specs!
Re: 1970 challenger "lowering the front end" [Re: Pacnorthcuda] #1433701
05/12/13 04:26 PM
05/12/13 04:26 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I always lower mine and do a home done alignment. Never had a problem with tires wearing... usually last longer than newer cars I have.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 1970 challenger "lowering the front end" [Re: Pacnorthcuda] #1433702
05/12/13 04:33 PM
05/12/13 04:33 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: 1970 challenger "lowering the front end" [Re: ssdodge70] #1433703
05/12/13 10:06 PM
05/12/13 10:06 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Will not hurt a thing...Lower and enjoy!
