Steering column ?? #143317
10/29/08 09:42 PM
10/29/08 09:42 PM
Dearborn Hts, MI
Sledge_57 Offline OP
Dearborn Hts, MI
A buddy of mine has a 70 Road Runner, not an A12 car but I figure you guys would know this, its an original 383 4 speed car.
He says his steering column has the arm on it under the hood for auto trans linkage and it also has the collar for the shifter inside the car.
He's looked at a couple other 4 speed cars and seen the same thing.
Did Ma just use one column in 70 for autos and manual trannys?
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Steering column ?? [Re: Sledge_57] #143318
10/29/08 09:55 PM
10/29/08 09:55 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Its not for column shift, but for reverse interlock.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Steering column ?? [Re: RoadRunner] #143319
10/29/08 10:04 PM
10/29/08 10:04 PM
Dearborn Hts, MI
Dearborn Hts, MI
How does that work?
He said there's no linkage attached at the moment and if he moves the collar then he can't turn the key?
Is there something he's missing, he did say there was a lot wrong on this car when he bought it.
Thanks for the help.
Doug
Re: Steering column ?? [Re: Sledge_57] #143320
10/29/08 10:50 PM
10/29/08 10:50 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
More info on the 1970 only lockout system can be found here;
https://board.moparts.org/ubbthreads/show...e=0#Post4773600
I have another project in the works that goes into it in greater detail also, it should be ready for all to see in a month or so.
Re: Steering column ?? [Re: Alaskan_TA] #143321
10/29/08 10:54 PM
10/29/08 10:54 PM
Dearborn Hts, MI
Dearborn Hts, MI
Thank you, I'll be sure he sees this tomorrow.
Doug
Re: Steering column ?? [Re: RoadRunner] #143322
10/29/08 11:09 PM
10/29/08 11:09 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
you're missing this
Re: Steering column ?? [Re: stateline] #143323
10/29/08 11:13 PM
10/29/08 11:13 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
And this -- the rod off the reverse link
Re: Steering column ?? [Re: Sledge_57] #143324
10/30/08 06:32 PM
10/30/08 06:32 PM
California
mickm Offline
mickm  Offline
California
can't tell you how glad i am that i read this post, and i almost passed it by!
mine is a 70 as well, and a while back i pulled into the garage, and the key would not turn to the lock position, and so was essentially stuck in the ignition switch! it would turn to the off, aux and start, but i couldn't turn it to lock.
so, that means the key is always in the car.
now i've been meaning to start a rebuild on the column for other reasons, but i was hoping to put that off. but with the key in the ignition, i can't leave the car out of my sight, and it drains the battery.
so after i read this, i thought, hmmmm.....
i don't have the reverse interlock mechanism in place, so the lever on the steering column is not connected to anything. sure enough, the lever had moved, and so the key was locked in place. i moved it back down, and removed the key!
this has been going on for about a month or more now
sometimes...
