Build almost done Thoughts on Power#'s Results are in #1432360
05/08/13 05:20 PM
05/08/13 05:20 PM
Minnesota
cudasteve72 Offline OP
Minnesota
Ok here it is. I was hoping you guys could help me guess power numbers for my build specs are as follow:
72 340 .030 over 4.070 bore
4" scat forged crank Scat forged rods Icon flat top pistons
Comp Cams 286 extreme energy hydraulic roller cam 236 intake 242 exhaust a .050" 110* lobe separation
Edelbrock Performer RPM Heads 2.02 1.60 valves 171 intake 77 cc intake/exhaust runners 65cc combustion chambers
PRW 1.5 Roller tip rockers
Edelbrock rpm air gap intake
ProForm 850 Street series Mechanical secondaries
Internally balanced getting ready for the dyno
Re: Build almost done Thoughts on Power#'s [Re: cudasteve72] #1432361
05/08/13 05:30 PM
05/08/13 05:30 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
gonna guess it should make a " real" 475 horsepower.
I had a similar 416 but with stage two ported eddies and a somewhat bigger flat tappet that made just a touch over 500.
Should go low-mid 11's if the car isnt real heavy( 3300-3400 pounds it should run in that range)
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Build almost done Thoughts on Power#'s [Re: B3422W5] #1432362
05/08/13 10:25 PM
05/08/13 10:25 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I'm guestimatin' 450-460 if the heads are stock. Ported (decent job), I'd put it up around 475-490.
Re: Build almost done Thoughts on Power#'s [Re: dodgeboy11] #1432363
05/08/13 10:40 PM
05/08/13 10:40 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Should be right where these guys are saying. I would guess 450-475 on my dyno. Which type of dyno are you testing on?
Keith
Re: Build almost done Thoughts on Power#'s [Re: Dunnuck Racing] #1432364
05/08/13 10:50 PM
05/08/13 10:50 PM
Northern Indiana
Northern Indiana
Tried to post a link,but couldn't. Go to the search at the top of the page and type in Hughes based 426 dyno test. I tested a 4.03 X 4.180 with stock Edelbrock heads to give you an idea.
Keith
Re: Build almost done Thoughts on Power#'s [Re: Dunnuck Racing] #1432365
05/28/13 04:02 PM
05/28/13 04:02 PM
Minnesota
Minnesota
The heads were right out of the box.
It was run on a Superflo Dyno.
http://www.youtube.com/watch?v=HNGQ-aAVmEc
The results 481 Horse 531 Torque
