Rear gear #1432075
05/08/13 12:20 AM
05/08/13 12:20 AM
oklahoma
69suprbee Offline OP
oklahoma
I have a 69 super bee 383 727.motor has a mild build.it has 3.23 open rear.i am going to put in a sure grip and go taller on gear.i do a little hiway driving but want more low end.thinking 3.55 or 3.73.anybody with experience going from 3.23 to either of these?3.55 enough of a difference?thanks for any opinions.david
Re: Rear gear [Re: 69suprbee] #1432076
05/08/13 12:29 AM
05/08/13 12:29 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
what size are your rear tires.
I am truckless..
Re: Rear gear [Re: 340SHORTY] #1432077
05/08/13 12:38 AM
05/08/13 12:38 AM
oklahoma
oklahoma
Sorry I left that out.275 15 60,a little over 27 tall on tear.tit also has a 280 h comp cams.that may be to much.its a little doggie on launch.727 shifts very well just rebuilt. Nice firm shifts motor runs well just not a lot of low end launch.any thoughts.?
Re: Rear gear [Re: 69suprbee] #1432078
05/08/13 06:50 AM
05/08/13 06:50 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
3.23s to 3.55s isnt really noticeable. 3.73s would be better but they are not available for all 3 cases IIRC. I like my 3.91s and would love to go to 4.30s but I have a OD 833 which helps a lot..
I am truckless..
Re: Rear gear [Re: 69suprbee] #1432079
05/08/13 02:21 PM
05/08/13 02:21 PM
Is this a automatic or stick shift tranny? If stick the no easy help by me unless you have acess to a 3.09 low gear tranny or a O.D. 833 . If your running a 727 think about changing the first gear ratio for more low end grunt I've done that on several BB cars, both street and strip and strip only
Re: Rear gear [Re: 69suprbee] #1432080
05/08/13 05:25 PM
05/08/13 05:25 PM
(1) 3.91 (2) swap in a 451 . Exhaust/brackets etc all will change over
Re: Rear gear [Re: 69suprbee] #1432081
05/08/13 08:10 PM
05/08/13 08:10 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
If you are currently running a stock converter, a converter change will probably make more differance than a gear change. A 280 cammed 383 would probably like a 3500ish 9.5 or 10 inch.
Re: Rear gear [Re: forphorty] #1432082
05/08/13 09:05 PM
05/08/13 09:05 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Kevin
Re: Rear gear [Re: forphorty] #1432083
05/08/13 09:29 PM
05/08/13 09:29 PM
oklahoma
oklahoma
Thanks for input everyone.i went ahead and ord a truetrac unit and some Yukon 3.73 gears.i will let you know how it does in the car.david
Re: Rear gear [Re: 69suprbee] #1432084
05/08/13 10:43 PM
05/08/13 10:43 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I have 3:73's in my B'cuda with 245/60-15's. I switched from the 3:23's that were in it while it had a 383/4spd. Seems like the perfect gear to me. Gives good low end grunt but ain't spinning the crap outta it at highway speeds....very drivable!! It now has a 470" in it(still 4spd) so it's lots of fun and still very highway friendly
Re: Rear gear [Re: Dcuda69] #1432085
05/09/13 08:48 AM
05/09/13 08:48 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
My 383 in my 70 Satellite is also a little lazy off the bottom. I think maybe just a bit too much cam in mine. I run 3.23's and have 275-60-17 rear tires. They measure right at 30". Last spring I put 3.91's in and ran them for a month or so. it helped it turn on sooner but it was exactly the same at initial start. I know it needs a converter, that would be the correct fix, but I am going to stay with the 1800 anyway. It runs pretty good from 2800 to 5500 or so.
...FAFO...
Re: Rear gear [Re: skicker] #1432086
05/09/13 02:44 PM
05/09/13 02:44 PM
oklahoma
oklahoma
sounds familiar.the bee has a 2000 stall in it.i am getting ready to put headers on it and upgrade the carb to a 750 cfm along with the posi and the 3.73.i hope its a different car.not that its bad now,just want to be able to burn both tires until i let off the throttle!
Re: Rear gear [Re: 69suprbee] #1432087
05/09/13 06:50 PM
05/09/13 06:50 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
You may or may not burn both tires until you let off with a 2000 RPM 'verter. I'm running the Hughes Whiplash (0.518 lift, 229 degrees intake 242 degrees exhaust at .050) cam with 3.73 gears and 275/15/60 rear tires. It took some doing, but I finally got it tuned correctly and now can cook the tires from a standing start. Just standing on it, not doing a brake burnout first. That's with a 'verter that flashes to 2500 RPM. Not that I want to blow the tires off from a start, that doesn't get you to far to quick. If I bring up the R's a bit against the 'verter first it gets better traction. That way I'm not shocking the suspension and breaking the tires loose so bad. Just sayin'.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Rear gear [Re: Junky] #1432088
05/09/13 07:29 PM
05/09/13 07:29 PM
oklahoma
oklahoma
thanks Junky.i think just a good 2 wheel tire spin for a little ways will keep me happy.i think the sure grip along with the 3.73 will make a good difference.if not then i will look at converter.
