What voltage should be on the out-side of the ballast?
#1431406
05/06/13 06:28 PM
05/06/13 06:28 PM
Posts: 1,179 Canada
demon
Canada
Fine tuning my electronic ignition. When I check the voltage on the coil side of the ballast resistor I have 6.25 volts. Same 6.26 Volts at the coil. That's with key on but not running.That's after it's been running and is hot. This seems too low to me. Has a stock 1.2 ohm ballast.
Re: What voltage should be on the out-side of the balla
[Re: IronWolf]
#1431409
05/06/13 07:32 PM
05/06/13 07:32 PM
Posts: 1,179 Canada
demon
Canada
I just measured 10.75 volts at the coil when running fully warmed up on a 75 degree day orange Mopar ecu. Running nice. Earlier today I swapped ballast resistors. The previous brand new one gave me 6.25 volts at the coil key on not running. Then I swapped an old extra and got 7.25 volts key on, not running. Both measured within .1 ohm of 1.2. Then I started it up and it ran noticebly better
[Re: IronWolf]
#1431412
05/06/13 08:55 PM
05/06/13 08:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The voltage is a simple matter to figure out. The voltage is dependent on the resistance of the coil and the ballast. If the ballast resistance is 1.2 ohms and the coil resistance is also 1.2 ohms then they will both drop half the voltage. So if the voltage at the input of the ballast is 14v, then you will see 7v at the coil + terminal. If the ballast is 1.2 ohms and the coil is .6 ohms with input voltage at 14V you will see 4.7V at the coil with the rest being dropped by the ballast resistor. http://www.allaboutcircuits.com/vol_1/chpt_5/2.html What other people see is not germane to your setup unless they are using the same ballast, same coil and have the same input voltage.
Re: What voltage should be on the out-side of the ballast?
[Re: demon]
#1431413
05/06/13 09:34 PM
05/06/13 09:34 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Which ballast resistor to use depends upon which distributor, coil, and ignition box you are running.. The primary purpose of the ballast resistor is to limit current not voltage to the coil.. Certain later aftermarket coils can take significantly, higher current (and voltage) that the earlier coils.. As well as certain boxes may be triggered by an analog or a digital signal which directly affects the amount of frequency/time the coil is being fired.. Disclose what distributor, ignition box and coil you are running then we can post more specific relevant comments.. Just my $0.02...
