Pro-trac front runners from Coker Tire #1430647
05/05/13 02:39 PM
05/05/13 02:39 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
I currently have MT drag race front runners on the car. They come with "Not for Street Use" all over them. I have been able to sneak around on them for years. Before that I ran a MT Sportsman front. Tire performed Ok just looked odd.
I ran the old Bias Volkswagon tires for years when they were still readily available. Pretty sure I made some 150 MPH runs on them.
I see Coker has a Pro Trac 560-15 that looks to be the same as what we used to call the VW tire. Has anyone ran this tire? What kind of MPH do you run in the quarter or have you been up to on the street with no issues?
I refuse to run a radial on the front with a Bias slick style tire on the rear. But, need something a little better than the ET front for street use during DRAGWEEK.
Leon
Re: Pro-trac front runners from Coker Tire [Re: Leon441] #1430648
05/05/13 04:20 PM
05/05/13 04:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I bought a road tire for the front but after having
them on I'm not happy with the width of them... I wanted
a road tire with a good speed rating(these are rated
to 135 but they are close on a full turn so I think
I will get something a bit narrower for clearance AND
less drag.... I dont recall what the Coker tire was
but I did look at them but they didnt have the speed
rating I wanted
Re: Pro-trac front runners from Coker Tire [Re: MR_P_BODY] #1430649
05/05/13 04:33 PM
05/05/13 04:33 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i think the MT sportmans are a good frontrunner for the street,lots of racecars that end up on the street have short suspensiontravel and this is where a flexible fronttire is of advantage since they eat up bad bumbs and such alot better than radials do,they are also safe at higher speeds at the track. a friend of mine ran something similar to volkswagen tires on the front of his malibu,yes its a much heavier car but those tires did not seem to appreciate the higher speeds at the track at all,he tried it more than once and they ended up with broken cords on the sides of the tires.
the softer frontrunners are also better if you come down alitle hard from a wheelstand.
and its never a good idea to mix radials and diagonals,my duster absolutely hates radialfronts and diagonal rears get insane squirely when there is grooves in the road,on the edge of dangerous.
Re: Pro-trac front runners from Coker Tire [Re: 1Fast340] #1430650
05/05/13 05:58 PM
05/05/13 05:58 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
I hear many run the ET front during DRAGWEEK. Wonder if their message on their tires lost some letters like mine did?
Leon
Re: Pro-trac front runners from Coker Tire [Re: Leon441] #1430651
05/05/13 08:40 PM
05/05/13 08:40 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have the Pro-Tracs on the front of my Savoy with ET street radials on the rear with ZERO handling issues on the street or strip.I chose them for the nostalgic look and they are tall enough to keep my oil pan off the street
I have only had them about 135 on the street and 127 on the track.
Gus
64 Plymouth Savoy
Dana 60
Re: Pro-trac front runners from Coker Tire [Re: fourgearsavoy] #1430652
05/05/13 09:00 PM
05/05/13 09:00 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
That's a big car.
My car only weighs 3,000 would you feel OK with them Pro Tracks at say 155 MPH?
Leon
Re: Pro-trac front runners from Coker Tire [Re: Leon441] #1430653
05/05/13 09:27 PM
05/05/13 09:27 PM
Dana Point, CA
Fast Yeti Offline
Fast Yeti  Offline
Dana Point, CA
Leon, I think Jim/572Charger runs them on his car and his car weighs 3800 or 3900 lbs. he street drives his car and has been over 150 mph. I had them on my car for a while a and they drove well but are heavy for a front runner if weight is a concern.
Re: Pro-trac front runners from Coker Tire [Re: Leon441] #1430654
05/06/13 01:35 AM
05/06/13 01:35 AM
Canada
CrAzYMoPaRGuY Offline
Canada
My brother ran them on his 1967 Coronet, he loved them.
He was 125mph in the 1/4
CrAzYMoPaRGuY
Re: Pro-trac front runners from Coker Tire [Re: Leon441] #1430655
05/06/13 07:58 PM
05/06/13 07:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
FWIW I ran radial fronts w/out handling issues w/bias rears but wanted to remove weight so I bought my buddys used MT et`s and they are fine street/strip and 12+ lbs lighter for the pair...........
Re: Pro-trac front runners from Coker Tire [Re: Thumperdart] #1430656
05/06/13 09:50 PM
05/06/13 09:50 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
I sold soft street tires for years. Back when these front tires were available at local tire shops. McCreary's were my hotest seller. I sold to everybody local who was just getting into racing with a street car. Back then inspection stations were not allowed to give you a pass in VA with radials on the front and bias on the rear. I knew full well about this. But, the Mustang crowd did not like the MT sportsman fronts nor did they like the old school 5.60-15 tires. Freinds who had Mustangs told me I was nutz and said they had no issues with the radials. So I backed off and quit telling people what to run on the front.
A guy showed up with skinnys on the front and wides on the rear. All radial. He wanted some sticky tires for the rear. Money was no object and back then ET streets were for serious racers or people with deep pockets. But, that is what he wanted. I never said a word. This guy complained and complained. Bad mouthed me all over town. I then found out this car was purchased with settlement money to begin with. I was never so releived when he blew the motor and sold the car.
Leon
Re: Pro-trac front runners from Coker Tire [Re: Leon441] #1430657
05/06/13 11:12 PM
05/06/13 11:12 PM
Rittman Ohio
Rittman Ohio
That's a big car.
Leon
My car is 3560# so I would think they would be OK on your car
Even when I am heavy on the brakes at tracks with short shut-down areas they handle good when most of the weight is on the nose
They balanced out nice when I mounted them so the carcass is pretty uniform.
Gus
64 Plymouth Savoy
Dana 60
Re: Pro-trac front runners from Coker Tire [Re: fourgearsavoy] #1430658
05/06/13 11:19 PM
05/06/13 11:19 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
Speed rating is not for a BURST of speed
its for sustained speed
Not like an alarm clock that will go off if you go
over the rating
The amount of time the tire would see the max speed would be in the 10's of 1,000ths of 2nds
But, I could be crazy too
Re: Pro-trac front runners from Coker Tire [Re: bigdad] #1430659
05/07/13 02:59 AM
05/07/13 02:59 AM
Arizona
Chris'sBarracuda Offline
Arizona
Re: Pro-trac front runners from Coker Tire [Re: Chris'sBarracuda] #1430660
05/07/13 03:41 AM
05/07/13 03:41 AM
MD
ADakotaRTGuy Offline
MD
Been running the Firestone champion tire on the fronts. 500/525 but in a 16 inch wheel. They have them in 15's, but really steady on the track with slicks. Been 124 with the Heavy Dakota and no issues. They come stock on the Viper drag packs from CCW.
Re: Pro-trac front runners from Coker Tire [Re: ADakotaRTGuy] #1430661
05/08/13 07:34 AM
05/08/13 07:34 AM
pa
572charger Offline
572charger  Offline
pa
they work great i been using them since 1999 ! they look like drag tire but are dot approved more side wall than a drag tire i use bias tires on the rear !( et streets) don't think id use them with drag radial mine is 3910 lbs i have 215 75 15 taller to keep my oil pan off the road !!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Pro-trac front runners from Coker Tire [Re: fourgearsavoy] #1430662
05/08/13 10:37 PM
05/08/13 10:37 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Gus
Shouldn't that guy in the left rear seat, looking over your shoulder, be wearing a helmet?
Re: Pro-trac front runners from Coker Tire [Re: Leigh] #1430663
05/08/13 11:17 PM
05/08/13 11:17 PM
Ohio
Cincylance Offline
Cincylance  Offline
Ohio
Gus
Oh man, that made me laugh out loud.
Re: Pro-trac front runners from Coker Tire [Re: Cincylance] #1430664
05/09/13 10:20 PM
05/09/13 10:20 PM
Rittman Ohio
Rittman Ohio
Gus
No my car is slow enough he won't need a helmet
Gus
64 Plymouth Savoy
Dana 60
Re: Pro-trac front runners from Coker Tire [Re: fourgearsavoy] #1430665
05/16/13 11:49 PM
05/16/13 11:49 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
How much are the Pro-tracs?????? I need some front tires for my duster....shoot,ill buy a good used set if anyone has any?????
Re: Pro-trac front runners from Coker Tire [Re: MIKES_DUSTER] #1430666
05/17/13 12:31 PM
05/17/13 12:31 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
$150 a peice
