How to adjust the choke thermostat/spring on my '85 Ram #1430083
05/04/13 11:30 AM
05/04/13 11:30 AM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
I have a new intake manifold well located choke thermostat recently installed on my '85 Ram, 318 engine.
I'm wondering if the choke is opening up too quickly as I have a "flat spot" upon accelerating when the engine is still quite cold (water temperature gauge hasn't moved off the "cold" peg yet).
I have to slowly creep across intersections until it warms up almost all the way.
Can I bend the rod going from the bi-metallic spring to the carb...or can the tension of the spring be adjusted tighter?
Re: How to adjust the choke thermostat/spring on my '85 Ram [Re: rnch] #1430084
05/04/13 01:16 PM
05/04/13 01:16 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Do you have a pic? I'm going to get my "new" choke thermostat in a few hours. Those guys (A&E parts 916-452-4962) are sharp. I can ask them if I know exactly what type "stat" you have. Or, you can give them a call after 11:00 PST today.
Re: How to adjust the choke thermostat/spring on my '85 Ram [Re: rnch] #1430085
05/04/13 02:35 PM
05/04/13 02:35 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You have the classic symptoms of a plugged intake heat crossover.
Re: How to adjust the choke thermostat/spring on my '85 Ram [Re: NITROUSN] #1430086
05/05/13 12:16 PM
05/05/13 12:16 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
Hmmmmm.... Perhaps so? It starts instantly when cold, in all temperatures and gradually steps down on fast/intermediate/curb idle.
Do I need to yank off the intake manifold to clean out the crossover?
Re: How to adjust the choke thermostat/spring on my '85 Ram [Re: rnch] #1430087
05/05/13 01:05 PM
05/05/13 01:05 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Yes, manifold will need to come off, and break out the chisels. Does the manifold get warm (hot) at the crossover area soon after cold start?
Before you do that check to see if the choke pull off is perhaps pulling the choke open too far, this would give you choke when cold, but no enrichment for cold run, soon after start.
If it is the pull off, adjustment is done by carefully bending the link.
Guessing, is this a 318 2v?
My '85 has a transplanted 318 4v, thermoquad, and it took a lot of fooling around to get things working properly, and I'm still not sure ...
It takes gasoline to interest me.
