Re: MSD Atomic EFI problems. Help please [Re: demon] #1429916
05/19/13 05:24 PM
05/19/13 05:24 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A for updating your title taking MSD off the hook on your "efi" issue, its the right thing to do, but not done often.
Re: MSD Atomic EFI problems. Help please [Re: jcc] #1429917
05/22/13 01:30 AM
05/22/13 01:30 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Ah ha! How about some credit where credit is due! Glad to hear you got it fixed.
Re: MSD Atomic EFI problems. Help please [Re: DaytonaTurbo] #1429918
05/22/13 10:29 AM
05/22/13 10:29 AM
Canada
demon Offline OP
demon  Offline OP
Canada
yes I do owe you some credit! Thanks for the tip about the reluctor gap!
Something so simple yet I overlooked it at first.
I am happy with the MSD Atomic system. I think I'll be installing them on more of my cars.
Re: MSD Atomic EFI problem solved! MSD was not at fault [Re: demon] #1429919
05/22/13 12:23 PM
05/22/13 12:23 PM
70Plum Offline
70Plum  Offline
The unit takes it's rpm signal from a white wire connected to the neg side of the coil.
No fault codes on the handheld but it shows no RPM on the display screen
I am about to install Atomic EFI on my 440 Challenger and it seems to me that you can't just attach the white wire to the neg side of the coil. The wiring diagrams all indicate connections to MSD 6A boxes, HEI, or Ready to Run distributors to get a 12V square wave signal.
After you fixed the reluctor gap did your display on the handheld start showing an RPM? If so, then I guess this is the ticket. But there is a post on the Atomic EFI forum about this from a user that had a similar issue to yours. The MSD response was
"It sounds like the Atomic is not getting a clean RPM signal from the coil negative. Unless you plan on installing an MSD Ignition box, I suggest using a GMR Pick-up (PN 8910) to provide a clean RPM signal to the Atomic."
You can read the whole thread at:
http://www.atomicefi.com/forum.aspx?g=posts&t=17019
I would be interested in your final wiring on this since I have standard Mopar Orange Box and don't want to fully convert to MSD 6A at this time. Maybe I will some day to take advantage of the Atomic controlling the timing, but for now I was thinking I might need this GMR Pick up or something similar. If I can just connect to the neg side of coil that would be easy.
Have gathered most of the parts for my Atomic install -- I am running a return line with Aeromotive regulator. Hope to install in the next few weeks.
Re: MSD Atomic EFI problem solved! MSD was not at fault [Re: 70Plum] #1429920
05/22/13 12:45 PM
05/22/13 12:45 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Do yourself a huge favor and dump the orange box now, it's an outdated design and doesn't give anywhere near the performance it should.
