driveshaft sensor on dana 60? #1428208
04/30/13 05:19 PM
04/30/13 05:19 PM
Chesterfield Twp. Mi.
John Burdine Offline OP
anyone have pics of how you mounted a driveshaft sensor on a dana 60? thanks!
Re: driveshaft sensor on dana 60? [Re: John Burdine] #1428209
04/30/13 05:26 PM
04/30/13 05:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
John it not a dana but it mounts the same way (I'm
pretty sure)... but this one I made because I couldnt
find anyone that offered it for a 8 3/4
EDIT
on the pick up I have the bolt holes for the snubber
and used them but you can drill and tap the housing
pretty easy and bend up a bracket easy
Re: driveshaft sensor on dana 60? [Re: MR_P_BODY] #1428210
04/30/13 06:08 PM
04/30/13 06:08 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
You need the Mark Williams Billet yoke, it sticks out a little further than stock and has the space for a ring. Stock yokes do not have enough room.
Re: driveshaft sensor on dana 60? [Re: Defbob] #1428211
04/30/13 06:16 PM
04/30/13 06:16 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have the same issue on my Dana so its still laying in the box. My racepak still gives me lots of good info but I know I'm missing out on a lot more.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: driveshaft sensor on dana 60? [Re: pittsburghracer] #1428212
04/30/13 07:57 PM
04/30/13 07:57 PM
sg66mopar Offline
sg66mopar  Offline
I put my collar on the front yoke 'cause I wasn't prepared to step up for the Mark Williams piece plus driveshaft rebuilding.
Maybe tomorrow I can get you a pic or two.
Re: driveshaft sensor on dana 60? [Re: sg66mopar] #1428213
04/30/13 09:15 PM
04/30/13 09:15 PM
i have the Mark Williams yoke, im' asking how you mounted the pick up, not the collar?
Re: driveshaft sensor on dana 60? [Re: John Burdine] #1428214
04/30/13 09:38 PM
04/30/13 09:38 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
I have mine mounted off one of the pinion snubber holes, if you have that style of Dana. If not what about a bracket bolted to the webbing on the side?
Photobucket sucks
Re: driveshaft sensor on dana 60? [Re: 72chrgrally] #1428215
04/30/13 09:46 PM
04/30/13 09:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I will assume he doesnt have the snubber holes...
all I can suggest John is to drill and tap the housing...
I've seen a couple of dana's done that way... they
had 2 1/4 X20 bolts holding it on
Re: driveshaft sensor on dana 60? [Re: MR_P_BODY] #1428216
04/30/13 10:18 PM
04/30/13 10:18 PM
i realy dont remember, but the rear has to come out anyway, i'll come up with something. prolly drill and tap.
thanks guys!
Re: driveshaft sensor on dana 60? [Re: John Burdine] #1428217
05/01/13 07:35 AM
05/01/13 07:35 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
You can either tap the housing and make a bracket or make a bracket that reaches all the way from the tube. The other way to get a speed sensor in the car is to mount one on the transmission yoke and make a bracket off the tranny.
Re: driveshaft sensor on dana 60? [Re: Defbob] #1428218
05/01/13 10:03 AM
05/01/13 10:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The problem with mounting it on the trans and slip
yoke on the drive shaft moving in and out... if its
on the pinion yoke they stay as a constant to each other
Re: driveshaft sensor on dana 60? [Re: MR_P_BODY] #1428219
05/01/13 04:20 PM
05/01/13 04:20 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
John, my Belvedere has one made from a 1/2" X 8" steel angle with a hole for the sensor at the end. I pie cut and welded one side of the bracket .090" to get the correct clearance to the magnet. Drilled a couple of vertical holes in the right side reinforcing rib of the axle housingto mount it. No pictures until Monday cause I'm out of town this week.
Doug
Re: driveshaft sensor on dana 60? [Re: MR_P_BODY] #1428220
05/01/13 05:37 PM
05/01/13 05:37 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
The few people I have talked to that have done it in this fashion have not had any issues. The yoke does not move enough to move the tone ring out of range of the sensor. I was looking into doing this for my Cutlass since I have a Strange S60.
Re: driveshaft sensor on dana 60? [Re: Defbob] #1428221
05/01/13 08:25 PM
05/01/13 08:25 PM
CHI-TOWN
REHBERGERRACING Offline
Redenbacher Racing
Redenbacher Racing
CHI-TOWN
Mines up front too. No problems.
Re: driveshaft sensor on dana 60? [Re: REHBERGERRACING] #1428222
05/01/13 08:32 PM
05/01/13 08:32 PM
PA.
"Little"John
"Little"John
PA.
I will be checking that out real soon. that would be great.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: driveshaft sensor on dana 60? [Re: Defbob] #1428223
05/01/13 09:04 PM
05/01/13 09:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok... my magnets are only a 1/4" diameter... I guess
I wouldnt have any problems either with a 4-link or
ladder bar but I was thinking more of a leaf spring
car, it moves a fair bit
Re: driveshaft sensor on dana 60? [Re: MR_P_BODY] #1428224
05/01/13 09:28 PM
05/01/13 09:28 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
When I installed my Racepak I was late to head out of state for a race. I took a 1"X1" square tube and welded a tab on the end so the sensor is adjustable. The tube is welded to the web on the side of the pinion snout. Never had any issues.
Re: driveshaft sensor on dana 60? [Re: Leon441] #1428225
05/02/13 05:31 AM
05/02/13 05:31 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Mine's like Leon's only it's bolted to the web. Cheap quick and easy.
Doug
Re: driveshaft sensor on dana 60? [Re: Defbob] #1428226
05/02/13 07:01 PM
05/02/13 07:01 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
thats not true i do not have a billet yoke on my car.
