Radiator upgrade question #1427989
04/30/13 01:07 AM
04/30/13 01:07 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I wanted to upgrade the cooling system on my 69 roadrunner runing a 383. As of now i have the stock 22 inch version but after a lot of reserch i think the best idea is to enlarge the opening and put in a 26 inch radiator in it's place.
I am looking for a driect fit 26 unit and the shroud so any advice on where to get them that is a resonable price?
Stu
Re: Radiator upgrade question [Re: MidPenMopar] #1427990
04/30/13 08:40 AM
04/30/13 08:40 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Are you having a cooling problem? If not, I would leave it alone.
If so, you can do what I did. Install a 26" Champion 2 row aluminum radiator in the existing 22" support. I didn't want to hack my nice support so I just spaced the rad out from the support a little so the air can get to the entire core. It worked perfect for me.
I think I paid around $200 for the radiator.
Re: Radiator upgrade question [Re: bobs66440] #1427991
04/30/13 09:11 AM
04/30/13 09:11 AM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
I wouldn't cut the opening out to 26 inches.Get a 22" Champion like the one pictured above. I put a 22" 3 core in my car like the one pictured above and it works great. My car never ran so cool.
Re: Radiator upgrade question [Re: bobs66440] #1427992
04/30/13 09:13 AM
04/30/13 09:13 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I agree. I got a 4 core Champion a few weeks back for the 69 Dart. It was only a 22" core support so I stayed with the 22" and added more cores. This was a direct fit to the radiator support with no modifications required.
...FAFO...
Re: Radiator upgrade question [Re: bobs66440] #1427993
04/30/13 09:23 AM
04/30/13 09:23 AM
Thanks for the advice and i will look into the Champion radiators, but i see no fan shroud in the photos. I thought you should always run a shroud for optium cooling??
Stu
Re: Radiator upgrade question [Re: MidPenMopar] #1427994
04/30/13 09:33 AM
04/30/13 09:33 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Yes, definitely use a shroud. Use a clutch drive if aren't already. You might also look into getting a 3rd row in your radiator if possible. tanks look big enough. it's not as good as having more width, but it does help. and I agree on not cutting, don't think you have to. be creative, and it's a good feeling when you don't have to cut
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Radiator upgrade question [Re: MidPenMopar] #1427995
04/30/13 09:41 AM
04/30/13 09:41 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Stu I just put this in a little over a week ago. I haven't made it to the shroud stage yet. I may see how it does without one and if its not needed I may not run one.
...FAFO...
Re: Radiator upgrade question [Re: skicker] #1427996
04/30/13 09:57 AM
04/30/13 09:57 AM
bobs66440 Offline
bobs66440  Offline
I don't run a shroud. It doesn't need it but yes, it's a good idea to have one regardless.
Re: Radiator upgrade question [Re: bobs66440] #1427997
04/30/13 10:10 AM
04/30/13 10:10 AM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
I don't have a shroud or a clutch fan. The radiator is drilled and tapped for a shroud though.
Re: Radiator upgrade question [Re: VincentVega] #1427998
04/30/13 10:20 AM
04/30/13 10:20 AM
The engine does not overheat at all in my own area of San Francisco where temps usually stay around 50 to 70 degress.
The issue is when i am away from the area and stopped just ideling in traffic on a very hot day. Then within minutes the temp climbs and the coolant boils over. On the freeway no matter how hot it gets i have no problems as long a i am moving at a good clip.
Here's what i have done:
Radiator has been hot tanked and all leaks repaired, i am running straight distilled water with an additive for the pump, I have a 17 lb cap, a nice new HD clutch fan and a high flow water pump.
Re: Radiator upgrade question [Re: MidPenMopar] #1427999
04/30/13 10:27 AM
04/30/13 10:27 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
classic problem. I think a shroud would help that a lot.. but obviously so would more capacity. how many rows in the radiator - 2?
How crafty are you? There are many options. Like was already mentioned, you could do a wider aluminum unit, offset it like shown above (which is a very elegant solution). I'd couple it with a shroud.
you could get a third row added to your stock radiator if can fit another row, and if you don't already have it. Again, couple with shroud.
You might also test the clutch drive - I've seen them bad right out of the box, especially if they are old were stored improperly (they can leak the fluid)
Are you running a thermostat (you should be)? What temp?
You could always buy an aux electric fan and mount it in front of the current setup. a simple switch could turn it on for you (or you could make it automatic with enough ingenuity). that'd be a huge help at idle when there is minimum airflow across the fins
don't forget - in a bind, roll down the windows and blast the heater. that can save the engine and bring the temps down. I've been there.. sure aint fun in the summer.
My father once routed a spare heater core in the front of his 64 413 New Yorker, which was prone to overheating. he plumbed it in via the heater hoses, and he said it never overheated again. sometimes you just need a bit more capacity. that's not very pretty though...
Which fan are you using? You want the 7 blade one
Re: Radiator upgrade question [Re: VincentVega] #1428000
04/30/13 10:36 AM
04/30/13 10:36 AM
bobs66440 Offline
bobs66440  Offline
For slow speed cooling problems you need to either speed up the water flow, increase capacity or increase the air volume being pulled through the radiator...or a combination of those.
I had this exact problem. I switched to a 26" radiator and it helped a little but not much. I installed a 18" mechanical nylon fan and smaller water pump pulley to speed up the water flow and now it's good now. I had to space out the pulley a little to clear the water pump bolts though.
Re: Radiator upgrade question [Re: VincentVega] #1428001
04/30/13 10:39 AM
04/30/13 10:39 AM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Im very happy with my 22 in radiator from Mancini Muscle Car Aluminum Radiators and it works fine even to my 505 stroker ! These are made to bolt right in and no hassel or drilling and hose fittings as stock but you need to mesiure and fill out a order form first
Re: Radiator upgrade question [Re: MidPenMopar] #1428002
04/30/13 10:43 AM
04/30/13 10:43 AM
Even after a boil out the OE cruddy rad may not be flowing enough to compensate for the lesser amt of air & water flow at lower speeds. I'd add a shroud & a smaller dia WP pulley & if that dont do it (& I suspect it wont) then as said a 3 or 4 row Champion. I have one ( 2 row) on a DD 318 & cools well tho cooling ain't an issue in my app & no leaks & just had to redrill 1 mounting hole which ain't nothing. Holler how it turns out/what fixes it for you. With it boiling over as you described there's definitely a serious problem
Re: Radiator upgrade question [Re: VincentVega] #1428003
04/30/13 10:44 AM
04/30/13 10:44 AM
I am running a 180 temp thermostat, yes i do have a shroud, the clutch fan is a 7 blade type.
The radiator is the stock type but maybe having it recored to three rows is the good answer to this problem?
Re: Radiator upgrade question [Re: Mopar Guy] #1428004
04/30/13 10:45 AM
04/30/13 10:45 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Your best solution would be to add a pusher fan in front of your radiator with a relay that will turn on when you need the extra cooling. The only advantage to an aluminum radiator is weight, and they look better, but they do not cool any better than a stock core. Only thing that would help would recore yours with a 3 core or buy a new one with more cores. It is your money, but the cheapest approach would be to add a fan.
JB Rhinehart, Realist
A-Body's RULE!
Re: Radiator upgrade question [Re: MidPenMopar] #1428005
04/30/13 10:48 AM
04/30/13 10:48 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I tend to type too much. these guys put it better - need more air across the radiator at slow speed. so - 7 blade fan (you got), shroud (you got), and as mentioned several times, an electric pusher fan at the front. modern cars do this, and it works out very well
Do you care if it will spoil the retro look? Otherwise, you'll need to do recore, or aftermarket radiator with a bit of fab (more money).
if you rig up an electric pusher fan, it will always still work with an aftermarket radiator if you need even more capacity, so it's not like it'd be a waste if it wasn't enough (but it probably would be).
Re: Radiator upgrade question [Re: Rhinodart] #1428006
04/30/13 11:03 AM
04/30/13 11:03 AM
That was my first idea as it seemed the easist, but i have asked all kinds of people who have added electric fans to their cooling systems and they said the only way to make it work correctly is go to a puller fan behind the radiator and not in front. There is no room for a puller unless it get rid of the clutch fan altogether unfortunitly.
Re: Radiator upgrade question [Re: MidPenMopar] #1428007
04/30/13 11:06 AM
04/30/13 11:06 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
They gave you bad advice. with dual pushers on an aluminum radiator, you wouldn't even need the mechanical fan (although it's nice to keep it there - big iron engines make a lot of heat and it helps to have something to blow it out of the engine bay).
Think about it. going down the road on the highway, the wind acts as a giant pusher fan. you don't need the mechanical fan, then. all that stuff is there for when the car isn't moving or is moving slowly.
the single auxillary pusher fan will be a big help
Re: Radiator upgrade question [Re: VincentVega] #1428008
05/01/13 09:54 AM
05/01/13 09:54 AM
California
norcalchryco1 Offline
California
Stu,
My dads superbee has a 3-row 22' radiator. It has a 440 in it. It has been driven to LA, Sacramento, etc on the hottest days of the year without a hitch.
That might be your easiest solution. Whatever you decide to do, good luck.
