69 Road Runner Hood paint questions PIC update #1427465
04/29/13 02:28 PM
04/29/13 02:28 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Painter will be painting the Black stripes on the Hood tomorrow and I have a couple of questions.
1.Hood and Inserts already painted B5 Blue.Are the Hood inserts painted
Black like the Hood or body color(B5) Blue?
2.What color is the aluminum block off plate painted? Orange?
2. How wide is the painted part in the center of the hood?
Probably be more questions.I am picking the RR up Wed and will share some pics then! Thanks for the help!
Re: 69 Road Runner Hood paint questions [Re: 68GTS383] #1427466
04/29/13 04:51 PM
04/29/13 04:51 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
1. Black 2. Black
1969 Hemi Roadrunner 2nd owner
Re: 69 Road Runner Hood paint questions [Re: 68GTS383] #1427467
04/29/13 07:32 PM
04/29/13 07:32 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's something that someone pointed out to me about the placement of the stripes.....The center cowl vent slots for lack of a better term that are not painted black equal 28 slots with 22 slots painted black by each stripe....I think that is correct.
Need to count the painted and unpainted (not again with the painted/unpainted thing ) vent slotted openings on a survivor when I get a chance.
Makes sense if there are 72 vent slots.
Re: 69 Road Runner Hood paint questions [Re: A12] #1427468
04/29/13 10:23 PM
04/29/13 10:23 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
This is the from the "survivor tent" at Mopar Nats
Re: 69 Road Runner Hood paint questions [Re: pacifica] #1427469
04/29/13 10:26 PM
04/29/13 10:26 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
72 vents and 30 are black.....
I'm wrong above. 30 slots are green in the center which means 72-30=42 black slots.
Re: 69 Road Runner Hood paint questions [Re: pacifica] #1427470
04/29/13 10:39 PM
04/29/13 10:39 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Wow that looks like my old car from 75
Re: 69 Road Runner Hood paint questions [Re: pacifica] #1427471
04/30/13 12:38 AM
04/30/13 12:38 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
So 21 are black on each side and 30 in the center are body paint. Now I remember that the person counted 21
Re: 69 Road Runner Hood paint questions [Re: 68GTS383] #1427472
04/30/13 09:20 AM
04/30/13 09:20 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
The aluminum block off plate is painted Semi gloss black. The screens for the air grabber are orange.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 69 Road Runner Hood paint questions PICS!! [Re: 69hemibeep] #1427473
05/01/13 02:27 PM
05/01/13 02:27 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Back at shop an hour ago. Let the fun begin! (Really!)
Re: 69 Road Runner Hood paint questions PICS!! [Re: 68GTS383] #1427474
05/01/13 02:28 PM
05/01/13 02:28 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Pic #2
Re: 69 Road Runner Hood paint questions PICS!! [Re: 68GTS383] #1427475
05/01/13 02:28 PM
05/01/13 02:28 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Pic #3
Re: 69 Road Runner Hood paint questions PICS!! [Re: 68GTS383] #1427476
05/02/13 04:14 PM
05/02/13 04:14 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
Nice!
Re: 69 Road Runner Hood paint questions PICS!! [Re: 68GTS383] #1427477
05/11/13 08:26 AM
05/11/13 08:26 AM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
You might have your painter black out the core support or folks on here will beat you up.
Re: 69 Road Runner Hood paint questions PICS!! [Re: Mopar Grandpa] #1427478
05/11/13 01:58 PM
05/11/13 01:58 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
This will make them happy
Re: 69 Road Runner Hood paint questions PICS!! [Re: 68GTS383] #1427479
05/11/13 05:37 PM
05/11/13 05:37 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Looks good. Please don't take this the wrong way, but if that's a blue interior, the door metal (& quarter metal panels) should be a darker blue than the B5 the body appears to be. Basically B7, but if you need codes, I have them. Interior door colors "break" at the weatherstrip.
Black int = black
White int = white ('69-'70)
Re: 69 Road Runner Hood paint questions PICS!! [Re: 68GTS383] #1427480
05/11/13 07:25 PM
05/11/13 07:25 PM
Sebring, Florida
Sebring, Florida
yes it will and BTW very nice looking car. Love that blue paint!!!!!!
Re: 69 Road Runner Hood paint questions PICS!! [Re: topside] #1427481
05/11/13 08:49 PM
05/11/13 08:49 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Actually I need the info. It is the two tone blue interior.Was the dash frame the same color?
Re: 69 Road Runner Hood paint questions PICS!! [Re: 68GTS383] #1427482
05/12/13 12:37 AM
05/12/13 12:37 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Dash frame, steering column, ashtray & windshield/headliner garnish had a flat "suede" textured finish similar to 600-grit sandpaper; DuPont code 9612LH "Majesty Blue". A-pillar, back glass garnish, console were a lower gloss, 9643LH Baltic Blue Metallic. Door/quarter metal, 4983L Baltic Blue Metallic. These are all original Dupont codes, but R-M was also a supplier and there are Ditzler codes as well. Defroster ducts BTW were not suede but low-gloss (molded in color); not an exact match to the dash color but close. Interior gloss was generally a bit less than the exterior paint on the door/quarter metal.
