Big Block Windage Tray Question #1426247
04/27/13 12:27 PM
04/27/13 12:27 PM
Wichita, KS
tmef Offline OP
tmef  Offline OP
Wichita, KS
This MP windage tray http://www.summitracing.com/parts/dcc-4120998/overview/make/dodge is labeled for use with center sump oil pans. Any reason it wouldn't work with a rear sump truck oil pan?
Re: Big Block Windage Tray Question [Re: tmef] #1426248
04/27/13 12:37 PM
04/27/13 12:37 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Wouldn't the center sump pan have a different location for the pickup? If so, the opening in the tray for the pickup tube would also be different that a rear-sump?
Re: Big Block Windage Tray Question [Re: cjskotni] #1426249
04/27/13 12:43 PM
04/27/13 12:43 PM
Wichita, KS
tmef Offline OP
tmef  Offline OP
Wichita, KS
I guess am looking at it like a smallblock windage tray. It works on both center and rear sump pans. Only difference is the shape of the oil pickup tube.
Re: Big Block Windage Tray Question [Re: tmef] #1426250
04/27/13 12:43 PM
04/27/13 12:43 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Let me see if I can find my box, but I am almost certain I used that tray with the truck pan. I needed the truck pan for the dart because the 402 hit the rack.
I got that tray and drilled some holes to help with oil drain back.
It was a little tricky to get the tray in as the truck pan has a long pickup tube, but it worked fine.
Again, I'll check in the garage for the box, I cannot seem to find my receipt.
383, Hemi 4-Speed, AlterKtion, D60
Re: Big Block Windage Tray Question [Re: cjskotni] #1426251
04/27/13 12:50 PM
04/27/13 12:50 PM
bc
3
37dodge Offline
37dodge  Offline
bc
I don't think you can use the tray with the truck pan it might be to shallow? i read that same place.
Re: Big Block Windage Tray Question [Re: Crazy68Dart] #1426252
04/27/13 12:51 PM
04/27/13 12:51 PM
Wichita, KS
tmef Offline OP
tmef  Offline OP
Wichita, KS
Fantastic. Thank you.
Re: Big Block Windage Tray Question [Re: Crazy68Dart] #1426253
04/27/13 01:57 PM
04/27/13 01:57 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Why would you want the MP piece.Unless you modify it they dont drain well.I bought one and it sits in the garage.I went Milidon.Better piece.Rocky
Chrysler Firepower
Re: Big Block Windage Tray Question [Re: tmef] #1426254
04/27/13 02:14 PM
04/27/13 02:14 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
WHOever wrote that ad for Summit is not the best informed ....
I have never done it ....YET ... but I have heard of others that have ...... put this on a FRONT SUMP motorhome pan ....
Re: Big Block Windage Tray Question [Re: therocks] #1426255
04/27/13 02:25 PM
04/27/13 02:25 PM
Wichita, KS
tmef Offline OP
tmef  Offline OP
Wichita, KS
Good point Rocky. I am going to order the Milidon tray and just do any notching or relieving needed to install the pickup tube. I doubt it will need any though. This is my first venture into BB territory so I am a little cautious I guess. Thanks to everyone for their input.
Re: Big Block Windage Tray Question [Re: tmef] #1426256
04/27/13 02:33 PM
04/27/13 02:33 PM
Florida STAYcation
Florida STAYcation
SINCE WHEN has the ROCKster ever had a good-point ? ...
He is living in the STONEage ! .... the tray not having good drainage ? .....
MAYbe if ROCKster is setting the rod-side-clearance with a LAVA ROCK and is winding up with a 50 to 80 spec ...
Re: Big Block Windage Tray Question [Re: therocks] #1426257
04/27/13 03:15 PM
04/27/13 03:15 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
1/2 the price. Drill and chamfer some holes, clean, and done.
Re: Big Block Windage Tray Question [Re: dOoC] #1426258
04/28/13 12:10 AM
04/28/13 12:10 AM
scratchnfotraction Offline
that looks like the pan that came in my stock 77-MH 440 engine with a front sump pan.
I swaped it to a rear sump/pick-up tube and re-used the tray.
Re: Big Block Windage Tray Question [Re: scratchnfotraction] #1426259
04/28/13 01:49 PM
04/28/13 01:49 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
When I was building my stroker I bought the MP tray and I had to beat and ding it pretty good to get the clearance I wanted
I ended giving the 440 Source tray a look and I was rewarded with a tray that fits perfect with only minor trimming around the pick-up
Very nice part http://store.440source.com/Windage-Tray-Stroker-New/productinfo/127-1002/
Gus
64 Plymouth Savoy
Dana 60
Re: Big Block Windage Tray Question [Re: Crazy68Dart] #1426260
04/28/13 07:58 PM
04/28/13 07:58 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Confirmed. This is the tray I used with the truck pan/pickup. Worked fine.
