Re: Big Block Windage Tray Question
[Re: tmef]
#1426250
04/27/13 12:43 PM
04/27/13 12:43 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
This MP windage tray http://www.summitracing.com/parts/dcc-4120998/overview/make/dodge is labeled for use with center sump oil pans. Any reason it wouldn't work with a rear sump truck oil pan?
Let me see if I can find my box, but I am almost certain I used that tray with the truck pan. I needed the truck pan for the dart because the 402 hit the rack.
I got that tray and drilled some holes to help with oil drain back.
It was a little tricky to get the tray in as the truck pan has a long pickup tube, but it worked fine.
Again, I'll check in the garage for the box, I cannot seem to find my receipt.
383, Hemi 4-Speed, AlterKtion, D60
[Re: Crazy68Dart]
#1426253
04/27/13 01:57 PM
04/27/13 01:57 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Why would you want the MP piece.Unless you modify it they dont drain well.I bought one and it sits in the garage.I went Milidon.Better piece.Rocky
Chrysler Firepower
[Re: tmef]
#1426254
04/27/13 02:14 PM
04/27/13 02:14 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
WHOever wrote that ad for Summit is not the best informed ....
I have never done it ....YET ... but I have heard of others that have ...... put this on a FRONT SUMP motorhome pan ....
[Re: tmef]
#1426256
04/27/13 02:33 PM
04/27/13 02:33 PM
dOOc
Florida STAYcation
Good point Rocky. I am going to order the Milidon tray and just do any notching or relieving needed to install the pickup tube. I doubt it will need any though. This is my first venture into BB territory so I am a little cautious I guess. Thanks to everyone for their input.
SINCE WHEN has the ROCKster ever had a good-point ? ...
He is living in the STONEage ! .... the tray not having good drainage ? .....
MAYbe if ROCKster is setting the rod-side-clearance with a LAVA ROCK and is winding up with a 50 to 80 spec ...
[Re: dOOc]
#1426258
04/28/13 12:10 AM
04/28/13 12:10 AM
Posts: 15,487 Florida
scratchnfotraction
that looks like the pan that came in my stock 77-MH 440 engine with a front sump pan.
I swaped it to a rear sump/pick-up tube and re-used the tray.
[Re: Crazy68Dart]
#1426260
04/28/13 07:58 PM
04/28/13 07:58 PM
Crazy68Dart
Canton, Ohio
Confirmed. This is the tray I used with the truck pan/pickup. Worked fine.
