proportioning valve flush ? #1426110
04/27/13 09:49 AM
04/27/13 09:49 AM
North Florida
RebelDart Offline OP
super street
super street
North Florida
Don't scold me, I've done that to myself enough. I bead blasted the prop valve and thought I had all holes plugged/capped , missed one somehow and caught it mid way through the process ..... can I flush this thing out and whats the best way ? 73 B body , not the brass jobs. Also need to flush lines ..........
Re: proportioning valve flush ? [Re: RebelDart] #1426111
04/27/13 10:47 AM
04/27/13 10:47 AM
We dont scold people here, at least not until the weekend rolls around & the haters (on here) come alive. Shop air/solvent to clean it out & same for the brake lines. I hear denatured alcohol is very good for that also.
Re: proportioning valve flush ? [Re: RapidRobert] #1426112
04/27/13 02:01 PM
04/27/13 02:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Brake clean is great.Then run some clean brake fluid thru it.Leave the ports open that go to the line hook it up and let the fluid go thru them after you use air and brake clean.Rocky
Chrysler Firepower
Re: proportioning valve flush ? [Re: therocks] #1426113
05/02/13 07:00 PM
05/02/13 07:00 PM
North Florida
super street
super street
North Florida
Thanks guys.
Re: proportioning valve flush ? [Re: RebelDart] #1426114
05/02/13 08:06 PM
05/02/13 08:06 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Have you seen the exploded view of that style valve? The valve can be completely taken apart for cleaning. That's what I'd do. Then it's just a matter of spraying it out with brake clean and compressed air.
Look here...
https://board.moparts.org/ubbthreads/upload2/7489638-poportioningvalve.jpg
Re: proportioning valve flush ? [Re: burdar] #1426115
05/02/13 08:53 PM
05/02/13 08:53 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
My concern about disassembly is the potential swelling of the rubber components inside the assembly... Kinda makes it hard to put back together... Been there, done that.
Curt
Oh yeah...THAT'S gonna leave a mark!
Re: proportioning valve flush ? [Re: Curt] #1426116
05/13/13 10:49 PM
05/13/13 10:49 PM
mi
E
ERAT340 Offline
ERAT340  Offline
E
mi
Does anyone know of a rebuild/ O ring kit for the cast proportioning valves?
