Rear End noise #142578
10/28/08 01:21 PM
10/28/08 01:21 PM
Missouri
Confusedcuda Offline OP
Missouri
Hi Guy's I have a 67 barracuda that came with a 273 and 7 1/4 rear end. I just put in a mild 340 and when I was driving it this weekend after a day of flogging it pretty good on the way home I noticed when I would turn and slowed down and sped up from stops a loud CLUNK would come from the rear end I believe. Once it started I headed straight home and when I was cruising on the hiway it seemed not to do it very often but once I slowed down, sped up or turned it would Clunk. Any ideas. I am all ready looking for a 8 3/4, Thanks
Re: Rear End noise [Re: Confusedcuda] #142579
10/28/08 01:30 PM
10/28/08 01:30 PM
Just South of The Motor City
limechallenger Offline
Check u-joints
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: Rear End noise [Re: limechallenger] #142580
10/28/08 04:30 PM
10/28/08 04:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check your trans mount.
Re: Rear End noise [Re: stumpy] #142581
10/28/08 05:03 PM
10/28/08 05:03 PM
md
mopars4ever Offline
mopars4ever  Offline
md
spider side gears in rear axle are broke, common problem in those rears
Re: Rear End noise [Re: mopars4ever] #142582
10/28/08 07:49 PM
10/28/08 07:49 PM
Nova Scotia Canada B2Y 1E4
SANDYinNS Canada Offline
pull the cover and have a look those parts are easy to change! If you get a piece of side gear in the ring and pinion you will ruin the whole thing
Sandy in Nova Scotia formerly drdodge340
68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute
-76 feather duster-76 duster-77 street van
- 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
Re: Rear End noise [Re: SANDYinNS Canada] #142583
10/28/08 09:41 PM
10/28/08 09:41 PM
Randys R&P has new side gears for them that might hold up longer than (1) weekend.
Re: Rear End noise [Re: RapidRobert] #142584
10/28/08 10:42 PM
10/28/08 10:42 PM
IN
ahy Offline
ahy  Offline
IN
Might be time to look for an 8 1/4 or 8 3/4 for that car. The 7 1/4 is probably a short term part behind a 340.
