Carb dumping fuel into crankcase....Holley?
#1425599
04/25/13 10:11 PM
04/25/13 10:11 PM
Posts: 1,679 Mansfield,Ohio
moparrulzzz
Mansfield,Ohio
In the process of welding my slots up in Dist. and firing up my 440 after dist reinstall my front bowl wouldn't fill with gas. I removed bowl cleaned it and put new needle valve in. I had it too high and started to puke gas out vent tube. Got the needle and fuel level adjusted, fired up car and is running WAY rich, pulled 2 plugs both soaked with gas, cleaned reinstalled plugs fired it up again and notice oil pressure at about 40 normally I am 70-75. Checked dipstick and its is way over full level and , thin and smells strongly of gas. This is a Holley Ultra Street Avenger 770 vac sec. Where do I start? did i dump all this fuel in crankcase when it was puking gas. I must have fouled out plugs which is why they were wet. Right now oil is draining, filter pulled, new plugs installed and carb is off. Not sure what to look for or where to start...point me in the right direction..pls!!
Re: Carb dumping fuel into crankcase....Holley?
[Re: RapidRobert]
#1425604
04/25/13 11:10 PM
04/25/13 11:10 PM
Posts: 30,464 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
believe me I was just at Summits sight looking at the Edelbrocks!
You know Doc is smiling
youtalkinabout ME RR ? ....
[Re: dOc !]
#1425607
04/26/13 12:13 AM
04/26/13 12:13 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
So it is the Holley carb fault cause you set the float too high....at least you can adjust it externally...do that with a eddy...and you gotta pull the top of the carb off again...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: moparrulzzz]
#1425610
04/26/13 01:49 AM
04/26/13 01:49 AM
Posts: 43,255 Bend,OR USA
Cab_Burge
Are you running a mechanical fuel pump? If so it probally is the source for the gas in the oil, not the carb. If you had said the the car would not turn over because of the cylinders being full of gas from the needles sticking I may have accepted a small amount of gas in the oil, not enough to dilute the oil to lose oil pressure though I have had motors that did hydraulic the cylinders due to leaky needles and seats, luckily they all stop spinning on the starter quick enough to not bend a rod or split a cylinder wall None of them foul the oil enough to make the oil thin enough to lose oil pressure, even with 5W 20 WT oil I now remove all the spark plugs before trying to start my motors any time I think I may have excess fuel in the cylinders and then spin it over with the coil disconnected
