Re: Flex fan/shroud
[Re: geol]
#1425268
04/25/13 11:03 AM
04/25/13 11:03 AM
RapidRobert
I would suggest a MP thermal clutch fan with the blades (7) spaced halfway into the shroud
Re: Flex fan/shroud
[Re: radar]
#1425270
04/25/13 01:05 PM
04/25/13 01:05 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
My 65 Belvedere 440 at 600 horse runs Summits stainless flex fan.It has an untouched 65 C body 22 inch rad with shroud.Even in the 90s it runs under 185 all day long.65s sit real close to the rad one of the problems with early Bs.I run a thin spacer and the fan has plenty of clearance between it and the rad and is just at the tip of the shroud.My kids 62 413 300 runs stock rad and same flex.It runs the same temp as mine even at the track.Mines been on at least 15 years and no problems.It normally sees over 7200 when I shift.Rocky
Chrysler Firepower
