Re: Question about heat crossover on a 360
[Re: Badge]
#1425027
04/24/13 06:34 PM
04/24/13 06:34 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Oh, finally found the picture. Never seen a manifold which covers that portion of the head, don't worry about it unless you just want to clean it. I thought we were talking about the crossover proper.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#1425028
04/24/13 07:03 PM
04/24/13 07:03 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not sure about that rear coolant cross over, my 87 Diplomat never had one. Maybe it was an EFI thing in trucks?
If the small gap shown in the picture above is where your debris is, then that's not uncommon, you can clean it out if you want, but it tends to collect stuff there anyway. It's not connected to anything. If it's the actual passageway in the intake, then you ought to clean it out, even if you plant to run an intake gasket without an opening for that passageway.
[Re: MoparforLife]
#1425031
04/24/13 10:38 PM
04/24/13 10:38 PM
Posts: 15,487 Florida
scratchnfotraction
The horse shoe shaped opening in the head around the heat cross over port is there to serve as an open air dam of sorts to break up with outside air the heat build up between adjacent exhaust ports and the hot heat crossover .
I keep mine clean with the airgun nozzle every now and then.
no water cross over on any SB I ever worked on.
