Eliminating AC 1985 D-150 #1424063
04/22/13 11:49 PM
04/22/13 11:49 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
Looking to change my 1985 D-150 sb from AC to Non AC, I think I have the correct crank pulley, as I understand I will need non AC alternator brackets, what about the water pump pulley and PS setup? Whatcombo of pulleys/brackets do I need?...FIY, I am going from a factory 4bbl setup to a RPM air gap with 600 AFB setup, will the factory kickdown bracket work with this changeover??
Re: Eliminating AC 1985 D-150 [Re: tt76400] #1424064
04/23/13 12:00 AM
04/23/13 12:00 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You'll need everything from a Non-ac smallblock. My buddy pitched his without all that hassle
Re: Eliminating AC 1985 D-150 [Re: 76dodgeboy] #1424065
04/23/13 12:09 AM
04/23/13 12:09 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I have successfully eliminated the AC using no extra pulleys, etc.
It requires some modification of a rib on the waterpump, and a shorter belt (of course).
I dont have any pictures, but you end up running the belt from the alternator to the crank. Its been a long time since I had "Lenny" so the particulars are a bit fuzzy.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Eliminating AC 1985 D-150 [Re: hp383] #1424066
04/23/13 12:12 AM
04/23/13 12:12 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
on my '87 all I did was change the fan pulley, run the altornater over the fan pulley to the crank.no issue with the steering pump.
1981 Dodge D150 360 auto
Re: Eliminating AC 1985 D-150 [Re: tt76400] #1424067
04/23/13 03:16 AM
04/23/13 03:16 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I just acquired a really sweet '87 D100 small block with inopearable AC and would like to make it work. Just curious, why take it out? Is it too expensive to make the system work with modern refrigerants?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Eliminating AC 1985 D-150 [Re: Polarapete] #1424068
04/23/13 11:33 AM
04/23/13 11:33 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
I had an 89 non air truck. All Chrysler did was put an ideler where the compresser was
Re: Eliminating AC 1985 D-150 [Re: wyldebill] #1424069
04/23/13 02:04 PM
04/23/13 02:04 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Not on any of mine they didn't
Re: Eliminating AC 1985 D-150 [Re: 76dodgeboy] #1424070
04/23/13 03:44 PM
04/23/13 03:44 PM
scratchnfotraction Offline
i have seen both.
on mine i have a 2 groove crank pully a 1 groove WP pully and can run a 1 or 2 groove alt with the non-A/C pullys.
the ALT/WP/Crank get 1 belt on the rear crank groove.
the PS gets a belt from crank on the front groove.
I have often in the past just run a belt from the alt to crank pully,if you remove the support rib on the neck of WP you can run 2 belts from crank to alt. I have left the A/C comp in place most times on stock junk.
but striping one down I just use the brackets and pullys with comp. removed.
to convert over to non-A/C pullys you just need the 2 groove crank pully,1 groove WP pully,non-A/C alt brackets.
the manual steer pullys/alt bracket are the same but crank pully has 1 groove.
I can post a pic of mine if you need a looky see.
I have used all of the multi-groove pullys with a/c brackets and just cut/trim them to clean up the look when ditching a/c
Re: Eliminating AC 1985 D-150 [Re: scratchnfotraction] #1424071
04/23/13 09:47 PM
04/23/13 09:47 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
Thanks to everyone for all the info. I have a sb sitting on a stand in the shop, think I will just grab my box of pulleys and brackets and mock it up to make sure I have everything I need. I just know that every sb I had in the past that I wanted to put a performance intake on, etc. was originally a AC vehicle and it was always a pain to find the right pulleys and brackets to eliminate the AC......
Re: Eliminating AC 1985 D-150 [Re: tt76400] #1424072
04/23/13 11:00 PM
04/23/13 11:00 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
junkyard should provide you this setup.
Re: Eliminating AC 1985 D-150 [Re: Golden-Arm] #1424073
04/24/13 08:54 PM
04/24/13 08:54 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I removed all the a.c. stuff and made two simple brackets and done.
Re: Eliminating AC 1985 D-150 [Re: moparborn] #1424074
04/24/13 08:57 PM
04/24/13 08:57 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
One is the bracket at the top rear of the alternator.
Re: Eliminating AC 1985 D-150 [Re: moparborn] #1424075
04/25/13 08:17 AM
04/25/13 08:17 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 84 Ram Charger the a/c locked up.I just removed the OE belts and got shorter ones.I measured them and then adjusted the alt for tension.Ran it that way for probally 4 years.Rocky
Chrysler Firepower
