Re: Eliminating AC 1985 D-150
[Re: 76dodgeboy]
#1424065
04/23/13 12:09 AM
04/23/13 12:09 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I have successfully eliminated the AC using no extra pulleys, etc.
It requires some modification of a rib on the waterpump, and a shorter belt (of course).
I dont have any pictures, but you end up running the belt from the alternator to the crank. Its been a long time since I had "Lenny" so the particulars are a bit fuzzy.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1424066
04/23/13 12:12 AM
04/23/13 12:12 AM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
on my '87 all I did was change the fan pulley, run the altornater over the fan pulley to the crank.no issue with the steering pump.
1981 Dodge D150 360 auto
[Re: tt76400]
#1424067
04/23/13 03:16 AM
04/23/13 03:16 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I just acquired a really sweet '87 D100 small block with inopearable AC and would like to make it work. Just curious, why take it out? Is it too expensive to make the system work with modern refrigerants?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: wyldebill]
#1424069
04/23/13 02:04 PM
04/23/13 02:04 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
I had an 89 non air truck. All Chrysler did was put an ideler where the compresser was
Not on any of mine they didn't
[Re: 76dodgeboy]
#1424070
04/23/13 03:44 PM
04/23/13 03:44 PM
Posts: 15,487 Florida
scratchnfotraction
i have seen both.
on mine i have a 2 groove crank pully a 1 groove WP pully and can run a 1 or 2 groove alt with the non-A/C pullys.
the ALT/WP/Crank get 1 belt on the rear crank groove.
the PS gets a belt from crank on the front groove.
I have often in the past just run a belt from the alt to crank pully,if you remove the support rib on the neck of WP you can run 2 belts from crank to alt. I have left the A/C comp in place most times on stock junk.
but striping one down I just use the brackets and pullys with comp. removed.
to convert over to non-A/C pullys you just need the 2 groove crank pully,1 groove WP pully,non-A/C alt brackets.
the manual steer pullys/alt bracket are the same but crank pully has 1 groove.
I can post a pic of mine if you need a looky see.
I have used all of the multi-groove pullys with a/c brackets and just cut/trim them to clean up the look when ditching a/c
[Re: moparborn]
#1424075
04/25/13 08:17 AM
04/25/13 08:17 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
My 84 Ram Charger the a/c locked up.I just removed the OE belts and got shorter ones.I measured them and then adjusted the alt for tension.Ran it that way for probally 4 years.Rocky
Chrysler Firepower
