Re: Transmission Cooler Mounting pics [Re: gearhead01] #1422913
04/21/13 08:59 PM
04/21/13 08:59 PM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
Second picture.
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Transmission Cooler Mounting pics [Re: dOc !] #1422914
04/21/13 09:04 PM
04/21/13 09:04 PM
You DON'T want something TOOOOO big ... it will kill some of the stall-speed.
Hmmmmm.........any truth to this?
Re: Transmission Cooler Mounting pics [Re: ] #1422915
04/21/13 09:43 PM
04/21/13 09:43 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I'm going with no.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Transmission Cooler Mounting pics [Re: bigtimeauto] #1422916
04/21/13 09:50 PM
04/21/13 09:50 PM
Renton Washington
Triple Threat Offline
Renton Washington
I'm going with no.
with NO
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Transmission Cooler Mounting pics [Re: Triple Threat] #1422917
04/21/13 10:42 PM
04/21/13 10:42 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm going with no.
with NO
Trans fluid temp WILL have an effect on stall rpm.
Fastest 300
Re: Transmission Cooler Mounting pics [Re: Crizila] #1422918
04/21/13 10:59 PM
04/21/13 10:59 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Not a trans cooler,car is a handshaker, but my PS cooler. I think if you mount it away from the radiator it is just as effective without any chance of heat transfer between the 2.
Mopar to the bone!!!
Re: Transmission Cooler Mounting pics [Re: 72Swinger] #1422919
04/21/13 11:54 PM
04/21/13 11:54 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Here's mine.
Put a BIG cooler on it... you can always cover some of it with tape/shield if it's too efficient, you can't go the other way!
Re: Transmission Cooler Mounting pics [Re: RobX4406] #1422920
04/22/13 12:11 AM
04/22/13 12:11 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thanks for the pics guys! Mine is mounted similar to how Rob has his.
Question for you guys, especially Crizila- I am assuming that the trans cooler lines HAVE to be run on the inside of the frame rail? I couldn't find anything about this in the NHRA rule book, and want to know for sure since my new headers are pretty damn close to the inner frame rail, and running them on the outside would make my life easier IF it is allowed.
Re: Transmission Cooler Mounting pics [Re: mshred] #1422921
04/22/13 01:19 AM
04/22/13 01:19 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine is mounted out back as well, crappy picture but it is in there above the wheelie bars, but you get the idea. Oh yeah soory about the dirt was the end of the year lasyear when I took it.
Re: Transmission Cooler Mounting pics [Re: mshred] #1422922
04/22/13 12:04 PM
04/22/13 12:04 PM
Az
Crizila Offline
Crizila  Offline
Az
No, nothing in the rule book ( in the general regs section ) on trans cooler line routing. Like many, my original lines ran along the left pan rail and then to the bottom of the rad tank. I routed them the same way until they were over the K member ( about mid pan ) and then ran them left in a square tubing shield past the belt area to the inside of the left frame rail and then forward. Since I have a rad with a built in trans cooler, I still utilize it (in line) with my external cooler. The in & out fittings from my rad make right angles to stay clear of the belt area. Losing a fan belt ( by itself )would not likely take out the cooler lines. Losing a blower belt is another story. It actually bent the eye bolt ( trailer tie-down) in the first pic. I only brought this up as a warning for those running something larger than a single groove belt - Serpentine belts, blower belts, etc. Easiest solution for me was to enclose the lines in the "danger" zone.
Fastest 300
Re: Transmission Cooler Mounting pics [Re: mshred] #1422923
04/22/13 03:09 PM
04/22/13 03:09 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
Mine is on the subframe close to the transmisson.
Section 8 Racing We are nuts about racing.
Re: Transmission Cooler Mounting pics [Re: bentwheel43] #1422924
04/22/13 03:15 PM
04/22/13 03:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont mind mounting the cooler a lengthy distance
from the trans... more line is just more fluid... most
of us put larger pans on the trans to get more volume
so the line helps for more volume
