Re: Transmission Cooler Mounting pics
[Re: MR_P_BODY]
#1422899
04/21/13 02:41 PM
04/21/13 02:41 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I have a clutch fan on the motor, and an elec. pusher, so I couldn't mount to the rad. I apologize for the crappy pic, and your grille support might be different, but I just hung it from the grille support, then made a brace to support the bottom.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: bigtimeauto]
#1422901
04/21/13 04:07 PM
04/21/13 04:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Nothing wrong with it in the rear if it gets air... yours has a fan... that plenty fine... is the fan on a thermo switch.... IF my Rampage needs more cooler I'm gonna put 1 or 2 more in series in the back with a fan.. but testing is needed(soon to come)
[Re: bigtimeauto]
#1422903
04/21/13 04:20 PM
04/21/13 04:20 PM
MR_P_BODY
yes it has a thermoswitch on the *in* side wired to the bat.
Cool.... IF I need more cooling I'll test to see if a air deflector will work or a fan... if I go with a fan it will have a thermo switch on it
[Re: OUTLAWD]
#1422904
04/21/13 04:52 PM
04/21/13 04:52 PM
Posts: 3,420 Toronto
mshred
Toronto
I have clutch fan on my engine as well...does this mean that the cooler will not work properly in front of the rad?
[Re: MR_P_BODY]
#1422907
04/21/13 08:01 PM
04/21/13 08:01 PM
mshred
Toronto
It doesnt mean it wont work BUT you might be blocking off needed air flow to the radiator.. thats dependent on how close your radiator is to being maxed out
well my rad is pretty big. Its not an a-body rad, but one that I got out of a late 80's 318 fifth avenue, a little trimming and it fits...shroud and fan from it too...Even on hot days sitting in traffic, my temps never get over 195 according to my mechanical gauge.
Also, I have about close to 2" between the cooler and the rad where I have mounted it (it is mounted off of the hood latch support)
[Re: mshred]
#1422908
04/21/13 08:37 PM
04/21/13 08:37 PM
OUTLAWD
Metro Detroit
No, it just means I did not have any room to mount directly in front of the rad, haha.
I am planning on putting a trans temp gauge in this season, as I am worried the cooler doesn't get sufficient airflow at low speed, IE in pits, staging, etc. without having a fan pulling the air through
[Re: OUTLAWD]
#1422909
04/21/13 08:53 PM
04/21/13 08:53 PM
Posts: 205 Illinois
gearhead01
Illinois
I am tucking the trans cooler behind the grill of the Valiant.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43 1977 Road Runner - N/B 11.02@ 119 Drag Radials
