Re: under dash voltage regulator
[Re: mickm]
#1422796
04/21/13 01:56 AM
04/21/13 01:56 AM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
where is this in a 70 b-body? i have a new one and want to install it to see if some gauge wierdness goes away. i looked in the FSM, and felt around a bit, but i can't find it.
Click on "Installation Manual for IVR4 Limiter" in the link below for info and pic of where it is located. http://rt-eng.com/rte/index.php/RTE_limiter
![](/ubbthreads/images/graemlins/beer.gif)
[Re: thehemikid]
#1422798
04/21/13 04:11 AM
04/21/13 04:11 AM
Posts: 4,179 California
mickm
California
Back side of 70 RR dash.
got it. should be able to grab it from there.
thanks! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Dakota_Don]
#1422802
04/22/13 11:03 PM
04/22/13 11:03 PM
moparfan53
NB, Canada
what is that thing supposed to do??
It reduces 12v down to 5v, which is what the oil pressure, coolant temp and fuel gauge operate on.
[Re: rth]
#1422803
04/23/13 01:05 AM
04/23/13 01:05 AM
Posts: 5,447 So Cal
Sinitro
So Cal
If you can't get big fingers in there, drop steering column for room.
No need to drop the column.. First disconnect the battery. Pull out the radio/panel, (4) phillips screws, release radio chassis support bracket. Now very EZ to reach inside to replace the voltage limiter/regulator...
Just my $0.02... ![](/ubbthreads/images/graemlins/wink.gif)
[Re: Sinitro]
#1422804
04/23/13 03:12 AM
04/23/13 03:12 AM
mickm
California
Just my $0.02...
will give it a shot and let you know how it goes! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: thehemikid]
#1422807
04/23/13 02:13 PM
04/23/13 02:13 PM
mickm
California
Sense my drivers seat & console are conveniently out of the way at the moment, I though I'd see if I could. I could get my left hand in just right of the radio & get all the way to it, & could have removed it,... if it wasn't for a wiring harness loom right up to it. I got my right hand to the loom but it didn't want to bend enough so I let the whole idea go. Hopefully your loom is a little father to the drivers side than mine.
If a person was able too get the limiter out from under the dash you might have a problem getting the little capacitor thingy plugged back in if it fell out.
i felt up there again, and i think that wiring loom is in the way. i don't think that thing is coming out without pulling the panel. need a little more time to look at it, but that's the way it seems at the moment.
[Re: mickm]
#1422808
04/23/13 03:59 PM
04/23/13 03:59 PM
Posts: 1,805 ky hills
thehemikid
ky hills
The panel coming out was the way it looked to me too. I had replaced my voltage regulator with the (new at the time) computer chipped deal a few yrs back over the solid state one,...but I can't tell ya how well it works cause my motors not in yet. ![](/ubbthreads/images/graemlins/tongue.gif)
[Re: thehemikid]
#1422809
04/23/13 06:28 PM
04/23/13 06:28 PM
Posts: 5,447 So Cal
Sinitro
So Cal
I have a 70RR so I know my suggestion works just fine.. Regarding the capacitor, not really required so if not there.. No biggee..
[Re: mickm]
#1422810
04/24/13 12:22 AM
04/24/13 12:22 AM
thehemikid
ky hills
Hey, mickm ...Fwiw...out in less than 3 minutes, back in, in a little over 2, from under the dash...BUT... no drivers seat & console.
Edit: I grabbed the upper ground lug between my 1st finger & thumb (left hand). Pulling & wiggling it out & rolling it towards the passenger side at the same time, cause the slots are sloppy allowing a lot of movement, while pulling the loom forward with my right hand.
There's enough slop that the loom may not be that big a deal, but with the seat in place, you may have to go through the radio, or.... ![](/ubbthreads/images/graemlins/wave.gif)
[Re: mickm]
#1422812
04/24/13 04:50 PM
04/24/13 04:50 PM
thehemikid
ky hills
That is a 9 volt battery with a LED high & low beam head attached that I've had for probably 10 yrs (give or take) that I used to see what I was doing under the dash. Expensive for its size but has been priceless to me through the yrs. I don't go anywhere without it, ...notice the warn battery surface.
There is a little 2" square opening just to the passenger side of the column at the bottom of the dash that gives a perfect view of what your doing. Edit: ware safety glassed though in case you was to drop it.
With the drivers seat in place one might need to be a contortionist,...never had to replace any late B-bodys before. I did replace one in a B-body Dart, but I think I just laid the dash panel forward. Also my forearms & hands are small. Your right hand & arm would need to be if everything is under the dash.
The radio route sounds pretty good.
