under dash voltage regulator #1422793
04/20/13 09:29 PM
04/20/13 09:29 PM
California
mickm Offline OP
mickm  Offline OP
California
where is this in a 70 b-body? i have a new one and want to install it to see if some gauge wierdness goes away. i looked in the FSM, and felt around a bit, but i can't find it.
Re: under dash voltage regulator [Re: mickm] #1422794
04/20/13 09:33 PM
04/20/13 09:33 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Some cars had it built into the fuel gauge. I don't know about your car.
Re: under dash voltage regulator [Re: Jim_Lusk] #1422795
04/20/13 10:35 PM
04/20/13 10:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think rally gauge dash had it built into the fuel gauge and standard gauges have this.
Re: under dash voltage regulator [Re: mickm] #1422796
04/21/13 01:56 AM
04/21/13 01:56 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Click on "Installation Manual for IVR4 Limiter" in the link below for info and pic of where it is located.
http://rt-eng.com/rte/index.php/RTE_limiter
Re: under dash voltage regulator [Re: moparfan53] #1422797
04/21/13 02:19 AM
04/21/13 02:19 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Back side of 70 RR dash.
Re: under dash voltage regulator [Re: thehemikid] #1422798
04/21/13 04:11 AM
04/21/13 04:11 AM
California
mickm Offline OP
mickm  Offline OP
California
got it. should be able to grab it from there.
thanks!
Re: under dash voltage regulator [Re: mickm] #1422799
04/21/13 12:26 PM
04/21/13 12:26 PM
NJ
rth Offline
rth  Offline
NJ
If you can't get big fingers in there, drop steering column for room.
Re: under dash voltage regulator [Re: mickm] #1422800
04/22/13 02:35 AM
04/22/13 02:35 AM
California
mickm Offline OP
mickm  Offline OP
California
looks like it's necessary to pull the dash panel to get to this. does it have to come all the way out? can someone give me a heads up on how to replace this?
Re: under dash voltage regulator [Re: mickm] #1422801
04/22/13 08:53 PM
04/22/13 08:53 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
what is that thing supposed to do??
Re: under dash voltage regulator [Re: Dakota_Don] #1422802
04/22/13 11:03 PM
04/22/13 11:03 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
It reduces 12v down to 5v, which is what the oil pressure, coolant temp and fuel gauge operate on.
Re: under dash voltage regulator [Re: rth] #1422803
04/23/13 01:05 AM
04/23/13 01:05 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
No need to drop the column..
First disconnect the battery.
Pull out the radio/panel, (4) phillips screws, release radio chassis support bracket. Now very EZ to reach inside to replace the voltage limiter/regulator...
Just my $0.02...
Re: under dash voltage regulator [Re: Sinitro] #1422804
04/23/13 03:12 AM
04/23/13 03:12 AM
California
mickm Offline OP
mickm  Offline OP
California
Just my $0.02...
will give it a shot and let you know how it goes!
Re: under dash voltage regulator [Re: Sinitro] #1422805
04/23/13 03:13 AM
04/23/13 03:13 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Sense my drivers seat & console are conveniently out of the way at the moment, I though I'd see if I could. I could get my left hand in just right of the radio & get all the way to it, & could have removed it,... if it wasn't for a wiring harness loom right up to it. I got my right hand to the loom but it didn't want to bend enough so I let the whole idea go. Hopefully your loom is a little father to the drivers side than mine.
If a person was able too get the limiter out from under the dash you might have a problem getting the little capacitor thingy plugged back in if it fell out.
Re: under dash voltage regulator [Re: thehemikid] #1422806
04/23/13 12:02 PM
04/23/13 12:02 PM
dogdays Offline
dogdays  Offline
Take one apart, you'll be surprised to find no solid state items in there, just a vibrating reed contact that only passes voltage around 5/12 of the time. If you looked at the output with an oscilloscope you'd see evenly spaced spikes of 12 volts.
It's sort of like a mechanical version of digital pulse width modulation.
Some folks are replacing this with a voltage regulator chip from computer power supplies, as they regulate 12VDC down to 5VDC much more cleanly.
R.
Re: under dash voltage regulator [Re: thehemikid] #1422807
04/23/13 02:13 PM
04/23/13 02:13 PM
California
mickm Offline OP
mickm  Offline OP
California
i felt up there again, and i think that wiring loom is in the way. i don't think that thing is coming out without pulling the panel. need a little more time to look at it, but that's the way it seems at the moment.
Re: under dash voltage regulator [Re: mickm] #1422808
04/23/13 03:59 PM
04/23/13 03:59 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
The panel coming out was the way it looked to me too. I had replaced my voltage regulator with the (new at the time) computer chipped deal a few yrs back over the solid state one,...but I can't tell ya how well it works cause my motors not in yet.
Re: under dash voltage regulator [Re: thehemikid] #1422809
04/23/13 06:28 PM
04/23/13 06:28 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I have a 70RR so I know my suggestion works just fine..
Regarding the capacitor, not really required so if not there..
No biggee..
Just my $0.02...
Re: under dash voltage regulator [Re: mickm] #1422810
04/24/13 12:22 AM
04/24/13 12:22 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Hey, mickm ...Fwiw...out in less than 3 minutes, back in, in a little over 2, from under the dash...BUT... no drivers seat & console.
Edit: I grabbed the upper ground lug between my 1st finger & thumb (left hand). Pulling & wiggling it out & rolling it towards the passenger side at the same time, cause the slots are sloppy allowing a lot of movement, while pulling the loom forward with my right hand.
There's enough slop that the loom may not be that big a deal, but with the seat in place, you may have to go through the radio, or....
Re: under dash voltage regulator [Re: thehemikid] #1422811
04/24/13 03:29 PM
04/24/13 03:29 PM
California
mickm Offline OP
mickm  Offline OP
California
the regulator is the 3 prong thingy, what is the other?
Re: under dash voltage regulator [Re: mickm] #1422812
04/24/13 04:50 PM
04/24/13 04:50 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
That is a 9 volt battery with a LED high & low beam head attached that I've had for probably 10 yrs (give or take) that I used to see what I was doing under the dash. Expensive for its size but has been priceless to me through the yrs. I don't go anywhere without it, ...notice the warn battery surface.
There is a little 2" square opening just to the passenger side of the column at the bottom of the dash that gives a perfect view of what your doing.
Edit: ware safety glassed though in case you was to drop it.
With the drivers seat in place one might need to be a contortionist,...never had to replace any late B-bodys before. I did replace one in a B-body Dart, but I think I just laid the dash panel forward. Also my forearms & hands are small. Your right hand & arm would need to be if everything is under the dash.
The radio route sounds pretty good.
