Trouble shooting turn signal lights #1422487
04/20/13 02:15 PM
04/20/13 02:15 PM
Upstate NY
454Baja Offline OP
454Baja  Offline OP
Upstate NY
I am chasing out my electrical gremlins and now am stumped on the turn signals, the car is 70 roadrunner. I have no signals and want to know where the power to the switch comes from. The steering wheels off and I have a new switch, tried it and does not work. I put a meter on the contacts and have no power. I am assuming power should be here on the contacts and the switch bridges the contacts. So I think I am not getting power to here. So it is bot a switch but the power source, the fuses look a intact and the schematic looks like the power comes thru the switch. The car turns over over and flashers work. Any ideas or leads to help me?
Re: Trouble shooting turn signal lights [Re: 454Baja] #1422488
04/20/13 03:10 PM
04/20/13 03:10 PM
NJ
rth Offline
rth  Offline
NJ
Did you check for power in and out of fuses? Do you have a flasher? Signal flasher is separate from hazards. I think it gets fed through ign switch to flasher. Do you have power to flasher?
Re: Trouble shooting turn signal lights [Re: 454Baja] #1422489
04/20/13 03:37 PM
04/20/13 03:37 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Here is a neat trouble shooting page from Year 1...
I don't remember who to give credit to, but this was posted last week..
Just my $0.02...
Re: Trouble shooting turn signal lights [Re: Sinitro] #1422490
04/21/13 08:18 AM
04/21/13 08:18 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Check the fuses as stated and the flasher.If the flasher is bad no signals.There are 2 of them.Rocky
Chrysler Firepower
Re: Trouble shooting turn signal lights [Re: therocks] #1422491
04/21/13 12:04 PM
04/21/13 12:04 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
or in my case, one flasher bad, directionals worked fine,until you had the lights on at night,then directional wouldn't flash just came on and stayed on,replaced all flashers= good
Re: Trouble shooting turn signal lights [Re: meepmeep70] #1422492
04/22/13 10:52 PM
04/22/13 10:52 PM
Upstate NY
454Baja Offline OP
454Baja  Offline OP
Upstate NY
what a pita
- first the aftermarket (china auto zone) turn signal switch with the wire contacts were to long so they did not make contact with the brass buttons in the switch. This prevented power into the circuit.Clipped the contact wires to allow the right fit and powered was transmitted.
- once I figured this out still the front right signal was not working, I metered the firewall connection where the signal comes out and there is nothing for power. The other 3 corners are working.
Now I will try the signal switch test enclosed above to see if its in the switch, at this point thats all thats left. Power is coming thru the flasher and the fuses are good.
I suspect I will pulling the column down for this one.
Thanks for the help
