Speedo cable #1422376
04/20/13 11:22 AM
04/20/13 11:22 AM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
I have a 65 Coronet, /6, 3sp. and don't know where to connect the drive end of the speedo cable. Can someone post some pics to show where it connects and where it is routed and anchored. The car did not have a speedo cable when I got it. The cable ends have female fittings and where I thought the cable went on the trans also has female threads. I need help.
Re: Speedo cable [Re: vjb] #1422377
04/20/13 04:51 PM
04/20/13 04:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The transmission should have a smooth hole where the end of the cable pushes in. The bottom end of the cable will look like the pic below.
Re: Speedo cable [Re: John_Kunkel] #1422378
04/20/13 05:13 PM
04/20/13 05:13 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
Where does the cable push in? I have obviously been looking in the wrong place.
v
Re: Speedo cable [Re: vjb] #1422379
04/21/13 05:23 PM
04/21/13 05:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It plugs in behind the mount pad on the drivers side. Orange line) There is a small threaded hole next to it for a bolt that holds a retainer for the cable housing.
Re: Speedo cable [Re: John_Kunkel] #1422380
04/21/13 10:10 PM
04/21/13 10:10 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
Thanks for the pix, that helped a lot. Now I find that I need the pinion gear.
Thanks for the help
V
