magnum head conversion pushrods still available? #1421921
04/18/13 11:00 PM
04/18/13 11:00 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
Have 2 small block budget builds going, one of them may be a magnum head swap on an earlier 318 shortblock, I am having difficulty locating the correct pushrods for this swap, I know MP used to offer them, but I cannot locate them anymore, are they still available, or are alternatives out there?
Re: magnum head conversion pushrods still available? [Re: tt76400] #1421922
04/18/13 11:12 PM
04/18/13 11:12 PM
scratchnfotraction Offline
IIRC, a few had said those are a tad short and used another length PR
maybe patrick or someone that saved the info will chime in.
seems like they mention a ferd PR for the fix???
I will write it down this time for sure.
Re: magnum head conversion pushrods still available? [Re: scratchnfotraction] #1421923
04/18/13 11:41 PM
04/18/13 11:41 PM
a few had said those are a tad short and used another length PR. seems like they mention a ferd PR for the fix???
X2. I'd wait & mock it up & see what exact length you need with a checking (adjustable) pushrod for .020-.030" preload with 1&1/2 threads showing (if using adj rocker arms) & see if an off the shelf pushrod is available in that length or how close to it you can come & go from there. EDIT there's some 7.375" ball/ball oil thru ones for $75 to your door & some 7.5" P4529555 ball/cup for $60 to your door in the for sale section. MORE EDIT My MP catalog says the P4529555 ones are 7.34". I believe you measure to the bottom of the cup which might explain that.
Re: magnum head conversion pushrods still available? [Re: RapidRobert] #1421924
04/19/13 10:17 AM
04/19/13 10:17 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
best way is to measure and then go to summit and see if you can find some pushrods the right length....with so many things that could alter pushrod length (has the block been decked? have the heads been shaved? head gasket thickness? is the cam a reduced base circle?, etc)....
if you are running a hydraulic roller and need pushrods just slightly longer than OEM magnum ones, these work great (.024-.036" longer depending on what you read nominal magnum pushrod length is) and are cheap at $30 for a set of 16. they're what I used on mine with a reground roller cam
http://www.summitracing.com/parts/cca-7828-16/overview/
2017 Grand Cherokee Overland
Re: magnum head conversion pushrods still available? [Re: patrick] #1421925
04/19/13 12:21 PM
04/19/13 12:21 PM
mesa arizona
moturbopar Offline
moturbopar  Offline
mesa arizona
I found that boss 302 pushrods, worked perfectly in MY magnum head 360 conversion. part # elgin PR-278s Picked up new set for under $35
here is a chart that shows the sizes they have.
http://catalog.elginind.com/app/engine_tech.asp?category=Push+Rods+by+Finish+Size
Re: magnum head conversion pushrods still available? [Re: moturbopar] #1421926
04/19/13 12:24 PM
04/19/13 12:24 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
Thanks to all for the info, just what I needed!
Re: magnum head conversion pushrods still available? [Re: tt76400] #1421927
04/19/13 10:50 PM
04/19/13 10:50 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I used Summit 7.650" pushrods and they have worked well for the last 5 years.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
