best place to purchase six pack carbs #1421608
04/18/13 12:05 PM
04/18/13 12:05 PM
USA
I
indy dart Offline OP
I
USA
Looking for a set of the six pack repro carbs. Ebay sellers have them at $1200. Is this the going price? Thanks
1970 B5 v-code Superbird
1971 Dodge Charger R/T in GA4
Re: best place to purchase six pack carbs [Re: indy dart] #1421609
04/19/13 12:12 AM
04/19/13 12:12 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
ProMax Carbs in Indy is a Holley dealer. They also have some custom 6-pak carb parts to help tune to "non-stock" motors.
Re: best place to purchase six pack carbs [Re: indy dart] #1421610
04/19/13 12:49 AM
04/19/13 12:49 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Moparts member Scott Smith with Harms automotive in Spokane, WA is a mopar repro carb. specialist. I've never bought anything from him, but I know he / they are highly respected in the hobby. I doubt their the cheapest, but it may be worth looking them up.
http://www.harmsauto.com/
Re: best place to purchase six pack carbs [Re: indy dart] #1421611
04/19/13 09:34 AM
04/19/13 09:34 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think Autozone, Advance, NAPA sell re-manned units for around $400. I think Summit even has them. Also check Atlantic Speed, I got my complete set-up for $2100.
Coming soon!!!!
Re: best place to purchase six pack carbs [Re: indy dart] #1421612
04/19/13 09:37 AM
04/19/13 09:37 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
http://www.atlanticspeed.com/productcart/pc/viewCategories.asp?idCategory=7
$360 for the outboards $520 for the primary. Mine worked great right out of the box
Re: best place to purchase six pack carbs [Re: Mr.Yuck] #1421613
04/21/13 02:55 PM
04/21/13 02:55 PM
Bismarck
CudaPete Offline
CudaPete  Offline
Bismarck
I ran accross this thread while searching for a place to buy complete 340 six pack setup.
So where do I find a complete six pack set up for my 340?
73 Cuda
73 Charger
73 Roadrunner
71 Charger
12 Ram Dually
15 Ram 1500
08 Nitro
Re: best place to purchase six pack carbs [Re: StealthWedge67] #1421614
04/21/13 03:24 PM
04/21/13 03:24 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
SteathWedge67,
Thank you for the supportive comments!
While I often have 4 barrel carbs in inventory, I do not typically have any 6 pack carbs for sale, I do restore them though so if the OP finds a good used original set I can make them look and run as good as new.
My standard price for restoring a complete 6 Pack setup is $799.00 and I'll replate all of the small intake and linkage parts at no added cost. So, if you can find a decent deal on some old crusty originals you might end up with a restored original set for similar or maybe a tad more money. One thing to consider is that the originals will retain thier value much better than the replacements will if you ever sell them.
Re: best place to purchase six pack carbs [Re: indy dart] #1421615
04/21/13 03:39 PM
04/21/13 03:39 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
About $1100 and change, plus free shipping from www.summiracing.com for the 340 carbs, which are the better choice whether your running a 340 or 440
Re: best place to purchase six pack carbs [Re: DAYCLONA] #1421616
04/21/13 03:44 PM
04/21/13 03:44 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
center carb....total set $1135
Re: best place to purchase six pack carbs [Re: DAYCLONA] #1421617
01/21/15 07:05 PM
01/21/15 07:05 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Sorry to hijack this thread, but I'm helping a friend research moving from a 4-bbl to a six pack on his 440, so have been combing thru old threads. This is the first time I've heard it said that the 340 carbs are a better choice for the 440. Can anyone confirm this, and elaborate on it? Thanks for any help.
Roger
Re: best place to purchase six pack carbs [Re: Fab64] #1421618
01/21/15 08:00 PM
01/21/15 08:00 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
slightly more CFM's if memory serves...
Re: best place to purchase six pack carbs [Re: mikemee1331] #1421619
01/21/15 10:01 PM
01/21/15 10:01 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
340 or 440 carbs are basically the same CFM, however the 4791 340 center is rated at 355 CFM, rather than the standard 350 CFM rating
I generally prefer the 340 end carbs for the larger air bleed orifices as they help promote earlier opening times than the 440 end carbs using the same spring ratios, that's the only difference, other than that, the carbs are very similar
Re: best place to purchase six pack carbs [Re: DAYCLONA] #1421620
01/22/15 01:03 AM
01/22/15 01:03 AM
Cab_Burge Online work
Cab_Burge  Online Work
if my memory is serving me well today I remember the original 340 carbs as being smaller in CFM and in actual measuring the internal components of their center carbs, both the CA and the 49 state carbs Regardless of the application you will need to tune and change them to make them work the best they can on your motor, including jetting, air bleeds and vacume pod springs
Re: best place to purchase six pack carbs [Re: Cab_Burge] #1421621
01/22/15 03:01 AM
01/22/15 03:01 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Didn't the 340 carb have a tab coming off of one of the boosters, for better fuel air mix or something.
