Trans Fluid #1421387
04/17/13 07:43 PM
04/17/13 07:43 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Car: 1966 Chrysler 300 383/4bbl all original w/ 120k miles on it.
I had a leak in my transmission pan gasket and the fluid level dropped to somewhere below the dipstick during a long highway roadtrip ( I was on the throttle hard for most of the way)
Went to drive it today and it was incredibly slow to shift into D, and would spin the engine w/ no forward motion. Checked the dipstick, and after tightening the trans pan bolts, filled the level back up to normal. The fluid on the dipstick is an icky brown color - now the trans will slowly shift into D but is slipping badly, and will just spin if I give it any power at all. Upshifts are not noticeable at all, and it won't take any power at all. Before yesterday upshifts were nice and firm and timely.
Could I have damaged the trans or do you guys think I can just change out the fluid and carry on?
I was thinking I could disconnect the trans cooler line at the radiator and let it idle in N while it drains into a pan and I pour fresh fluid in through the dipstick tube?
Re: Trans Fluid [Re: jeebis44] #1421388
04/17/13 08:49 PM
04/17/13 08:49 PM
I'd pull the pan & see if the filter looks plugged
Re: Trans Fluid [Re: RapidRobert] #1421389
04/19/13 08:56 PM
04/19/13 08:56 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Nothing in the pan, won't have a replacement filter for a few more days - has anyone here used Trans X treatment before?
Re: Trans Fluid [Re: jeebis44] #1421390
04/19/13 08:59 PM
04/19/13 08:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Don't add any trans fix in a can to your trans unless you are prepared to rebuild it tomorrow. Pure crap and does more harm than good.
Re: Trans Fluid [Re: jeebis44] #1421391
04/20/13 12:16 AM
04/20/13 12:16 AM
Cab_Burge Online work
Cab_Burge  Online Work
Make sure and draian the converter and adjust the bands, both of them As already siad, DO NOT add any additives Do these things and be ready for some improvemnents Let us know your results
Re: Trans Fluid [Re: Cab_Burge] #1421392
04/20/13 11:11 AM
04/20/13 11:11 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
how should the bands be adjusted?
Re: Trans Fluid [Re: jeebis44] #1421393
04/21/13 04:32 PM
04/21/13 04:32 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Changed out fluid and a little better but still very sloppy shifting. How do I correctly adjust the bands?
Re: Trans Fluid [Re: jeebis44] #1421394
04/22/13 03:16 AM
04/22/13 03:16 AM
The front band, depending on what the factory service manuals calls for is to loosen the lock nut on the front band and tighten the adjuster,it is external (while holdiing the lock nut) to 72 inch lbs and then back the adjuster bolt off from 1.5 to 2.0 full turns and lock it down, Google the specs for your year tranny and motor size The rear band is harder to get to, you have to drop the tranny pan
Re: Trans Fluid [Re: Cab_Burge] #1421395
04/22/13 10:16 AM
04/22/13 10:16 AM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
Check the t.v lingage at the carb and make sure the spring is still hooked to the carb.
When that breaks and falls of it will do some of the same problems your talking about.
Re: Trans Fluid [Re: BRONZEBEE] #1421396
09/30/13 10:20 PM
09/30/13 10:20 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Update - I replaced all the fluid and filter, linkages are good, adjusted the front band and still the same problem. If I just barely give it any throttle, it shifts from 1-2 and 2-3 with a noticeable shift... if I give it any power at all it just slips.
Re: Trans Fluid [Re: jeebis44] #1421397
09/30/13 11:49 PM
09/30/13 11:49 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Was the old fluid black and smell burnt?
Re: Trans Fluid [Re: ademon] #1421398
10/01/13 12:22 AM
10/01/13 12:22 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
It was more brown and yes it smelled burnt. The old filter had specks of metallic particles in it and there was a solid layer of grey sludge in the bottom of the pan.
Re: Trans Fluid [Re: jeebis44] #1421399
10/01/13 02:22 AM
10/01/13 02:22 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Sounds to me like it is done. Time for a rebuild.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Trans Fluid [Re: jeebis44] #1421400
10/01/13 02:48 AM
10/01/13 02:48 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
You have no rear clutch left for sure......it's gotta come out.
Re: Trans Fluid [Re: superwrench] #1421401
10/01/13 01:35 PM
10/01/13 01:35 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Bummer - thanks for the input
Re: Trans Fluid [Re: superwrench] #1421402
10/01/13 02:22 PM
10/01/13 02:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I used TransFusion if you can find it.Ive used it at home and the shop for 30 years.Its one additive that works.It wont fix an internal problem but Ive used it in some fairly bad trannys and it did wonders.Change the fluid and filter and add a quart.If no major problems it will help.Rocky
Chrysler Firepower
Re: Trans Fluid [Re: therocks] #1421403
10/01/13 03:47 PM
10/01/13 03:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If it shifts real quick as you say you should make sure the throttle press rod is set right. That will cause fast shifts if to low and can cause the trans to slip as it also acts on line pressure. Even if its wasted you want to get the throttle pressure right so you dont mess up a rebuilt trans. Ron
Re: Trans Fluid [Re: 383man] #1421404
10/01/13 06:15 PM
10/01/13 06:15 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
What is the proper way to adjust that rod?
