Re: Trans Fluid
[Re: jeebis44]
#1421388
04/17/13 08:49 PM
04/17/13 08:49 PM
RapidRobert
I'd pull the pan & see if the filter looks plugged
Re: Trans Fluid
[Re: superwrench]
#1421402
10/01/13 02:22 PM
10/01/13 02:22 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
I used TransFusion if you can find it.Ive used it at home and the shop for 30 years.Its one additive that works.It wont fix an internal problem but Ive used it in some fairly bad trannys and it did wonders.Change the fluid and filter and add a quart.If no major problems it will help.Rocky
Chrysler Firepower
