4-Speed Shifter Install Clearance Issues
#1420985
04/16/13 10:45 PM
04/16/13 10:45 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I am installing the shifter into the Dart. It is a competition plus, and was with the transmission when I got it years ago.
Gus went through the transmission and shifter for me.
I mocked this stuff up a long time ago. I am pretty sure it cleared, but I may not be remembering correctly.
One of the rods (shorter) is hitting the cross member, and the other is very close. The reverse rod fits fine.
This car was originally an auto car. Did they clearance the cross member at all from the factory on 4-speed cars?
Thanks for all the help.
383, Hemi 4-Speed, AlterKtion, D60
Re: 4-Speed Shifter Install Clearance Issues
[Re: Crazy68Dart]
#1420986
04/16/13 11:43 PM
04/16/13 11:43 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Hi Andy The only thing I can think of is you changed the transmission mount it may have put the trans closer to the crossmember You may have to put a few notches in the crossmember for the larger diameter shift rods from the Super Shifter so they clear. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Crazy68Dart]
#1420988
04/17/13 07:49 AM
04/17/13 07:49 AM
Crazy68Dart
Canton, Ohio
Gus, it is the same mount and cross member as I mocked it up with. It very well may be that I am not remembering correctly. I'll mark the interference points pull the shifter and grind away.
[Re: Crazy68Dart]
#1420989
04/17/13 10:52 AM
04/17/13 10:52 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
The lower rod (reverse) Does not look like the correct one for A body. Is that the one thats hitiing?
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: Jim_Lusk]
#1420991
04/17/13 02:39 PM
04/17/13 02:39 PM
Crazy68Dart
Canton, Ohio
One other thing. Unless you had the engine in the angle may have been wrong and the shifter is real close when it's right.
I also agree with Mike on the looks of the reverse rod.
Jim, when I mocked it up it was with a bare 400 block, heads, and intake, with the same bell housing, block plate, etc. Now it is attached to a different motor (383). If it is that close "when it is right" then maybe things have changed just enough.
The car is up on jack stands so all the weight of the motor, and front end may be moving things around slightly.
The reverse rod has lots (all relative when you are talking about a big block in an A body of course, lol) of clearance.
Once I make some clearance, I need to get the shifter handle on and make sure there is clearance for the rods in all positions.
[Re: Crazy68Dart]
#1420992
04/17/13 04:09 PM
04/17/13 04:09 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
your rods dont look right to me. these are the correct A-body shift rods with a competition plus shifter.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: Cab_Burge]
#1420996
04/17/13 06:33 PM
04/17/13 06:33 PM
Posts: 43,565 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
There is actually a notch in the crossmember for 4-speed cars. You can just make it out in this pic of my factory 383 4-speed Dart.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Cab_Burge]
#1420997
04/17/13 06:37 PM
04/17/13 06:37 PM
Crazy68Dart
Canton, Ohio
Here are some pictures. Appears that this A-body shifter/rods is not what I was told it was. My fault for believing the guy 10 years ago I guess.
Can anyone ID this stuff?
[Re: Crazy68Dart]
#1421002
04/17/13 06:40 PM
04/17/13 06:40 PM
Crazy68Dart
Canton, Ohio
long rod
