Piston oilers
#1420474
04/15/13 09:31 PM
04/15/13 09:31 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
My R5 engine has them. They are common in circle track. I blocked the stuff off in my old R3 block.
Thought they may come in handy with street driving and all. Bob was told to leave them be so they are still there.
Problem is the oil gets really warm and of course the pressure drops a lot with hot oil. I thought about a cooler. I suspect a lot of the heat is from the oil sprayed on the bottom of the piston. The piston is being cooled but at the cost of the oil temperature.
Does anyone have an engine that previously had this such as a NASCAR R5 and took them out?
I don't want to make room for an oil cooler.
Leon
Re: Piston oilers
[Re: Leon441]
#1420475
04/16/13 11:49 AM
04/16/13 11:49 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Leon, Make room for an oil cooler! Our first Drag Week was in 06 with a tall fill RB Block. Cruise oil press. would be 50 at the start of a long drive, and 15-20 by the end of it, kinda scary!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
Re: Piston oilers
[Re: Duner]
#1420478
04/16/13 01:53 PM
04/16/13 01:53 PM
Posts: 169 Finland, Europe
Ck[FIN]
Finland, Europe
Oil gets also pretty hot in my R5 with those oil sprayers. If you are driving anything else than drag race, you need the cooler. I use full synthetic 5w-50 mobil and it keeps my pressure at 15psi(idle) in really hot days, engine water temp at 200F.
When i flip the throttle above 2000rpm, pressure goes to 65psi.
-1965 Valiant 9.03s 358cu.in R5P7-
Re: Piston oilers
[Re: Leon441]
#1420479
04/16/13 08:20 PM
04/16/13 08:20 PM
Posts: 1,417 Chicago, IL
blownEFI
Chicago, IL
Just installed oil jets in my 542 turbo street car engine. Has only run on the dyno so far. I have a huge oil cooler in the car. Hoping for good results. I agree with everyone else... keep the jets and figure out how to fit a cooler.
"These go to eleven", Nigel Tufnel
Re: Piston oilers
[Re: blownEFI]
#1420480
04/16/13 09:23 PM
04/16/13 09:23 PM
Leon441
Lynchburg, VA
After reading the replies I decided to put the one I removed back and put the pan back. When I tightened the bolt the oiler just kept going the wrong way. So after looking at the other I noticed one was missing a nozzle and the others were aimed all over the place.
Screw it they are coming out.
Leon
Re: Piston oilers
[Re: Ck[FIN]]
#1420484
04/17/13 08:46 PM
04/17/13 08:46 PM
Leon441
Lynchburg, VA
Interesting point. But, there is plenty of oil being slung off the cranks shaft and connecting rods IMO. The rods have oil passages to the wrist pins. Personally I think the NASCAR boys do this to help cool the pistons as their engines are run hot.
Mopars generally drip oil from the cam on to the crank and that is thrown everywhere not to mention the oil from the heads.
R3 race prepped block use tubes over the cam and roller cam bearings. Also we ran very small feed holes in the lifter bushings. Drain back lines from the heads and a big hole next to the oil pump gear to allow oil to fall behind the last counterweight on the crank. Maybe not as dry as an R5 which also has the camshaft tunnel seals but very close.
I actually know it is not a huge issue because there are plenty of EEI aluminum blocks running with the piston oiler passages completely elliminated. But, some have the enclosed cam tunnel cut to clear the crank also. Just depends on how much stroke they are running.
Leon
