The Ridge 4-12-13 #1420272
04/15/13 02:25 PM
04/15/13 02:25 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
http://veritasimagerynw.smugmug.com/Cars...p;lb=1&s=X2
Took the car to the first track day of the year. The location was the The Ridge in Shelton WA. Lots of grip at this track and ton of elevation changes. Very challenging but fun....of course!
Got a few good sessions in but ended up finally breaking the transmission. Pushing fluid out the front and not cooling. This thing has been hanging on for a few years now. We knew it was the weak link in the drivetrain, but now we have to address it. To the shop today for a report on the damage.
The car was fast and handled great, look forward to getting out there again.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: The Ridge 4-12-13 [Re: Viol8r] #1420273
04/15/13 02:42 PM
04/15/13 02:42 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Lookin great. It rained over here, now and then, yesterday and Sat.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: The Ridge 4-12-13 [Re: Viol8r] #1420274
04/15/13 02:53 PM
04/15/13 02:53 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
You look like you are having entirely too much fun!!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: The Ridge 4-12-13 [Re: Viol8r] #1420275
04/15/13 03:03 PM
04/15/13 03:03 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Your Charger looks great on track! Hang in there and do more events!!
Do you know anything about the Challenger (pic #50)? Is he on our chat lines?
Re: The Ridge 4-12-13 [Re: Mopar Mitch] #1420276
04/15/13 03:15 PM
04/15/13 03:15 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The one with the Subaru rear wing? Oh my!
Mopar to the bone!!!
Re: The Ridge 4-12-13 [Re: 72Swinger] #1420277
04/15/13 03:16 PM
04/15/13 03:16 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Marty the car looks great! Check the angle of your trans pan in the frontal pic. We all need some engine mounts that keep the motor in place without stupid strut bandaids.
Re: The Ridge 4-12-13 [Re: 72Swinger] #1420278
04/15/13 03:26 PM
04/15/13 03:26 PM
amxautox Offline
amxautox  Offline
A Schumacher torque link would help to keep the left side of the engine from rising up. Helps in my Charger.
I forget the name of the motor mount that has a built-in strap/link/tab for that. I've also read about a mod you can make and have seen a picture of the mod, but it's been a long time ago. And then I've heard of drilling a hole thru the two metal parts and rubber pad and installing a bolt to limit the travel of the metal parts from spreading apart.
Tom
author unknown
Re: The Ridge 4-12-13 [Re: amxautox] #1420279
04/15/13 03:38 PM
04/15/13 03:38 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Schumacher used to sell a left side motor mount that was re-inforced to prevent movement. I don't have a current catalog, but I installed one in my '64 Polara and it was street-friendly without being harsh like a solid mount would be.
2008 Honda Element
Re: The Ridge 4-12-13 [Re: Polarapete] #1420280
04/15/13 03:40 PM
04/15/13 03:40 PM
amxautox Offline
amxautox  Offline
Mine is a rod with one rubber cushioned end, and hime joint/sypherical rod bearing on the other. Kinda like a sway bar end link.
Tom
author unknown
Re: The Ridge 4-12-13 [Re: amxautox] #1420281
04/15/13 03:44 PM
04/15/13 03:44 PM
amxautox Offline
amxautox  Offline
Tom
author unknown
Re: The Ridge 4-12-13 [Re: amxautox] #1420282
04/15/13 03:50 PM
04/15/13 03:50 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That is kinda my point. Instead of making a mount that can hang, they sell an ADDITIONAL component to bandaid their stock isolators. Here is my fix, and it works, but the passenger side needs attention.
Re: The Ridge 4-12-13 [Re: 72Swinger] #1420283
04/15/13 03:59 PM
04/15/13 03:59 PM
amxautox Offline
amxautox  Offline
That looks like the bolt idea I've read about.
Then there is another that has a tab that bends over the top/bottom plate that is part of the bottom/top plate. It's attached to one plate, then bends around the edges to the other plate to keep them from spreading under heavy throttle, but rides softly on the rubber during 'normal' driving. I've seen a picture of it.
Tom
author unknown
Re: The Ridge 4-12-13 [Re: Mopar Mitch] #1420284
04/15/13 05:34 PM
04/15/13 05:34 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
I just met Mel, he is from Snohomish. Heck of a nice older gentleman. The car was apparently damaged badly a few years back buy a Semi-truck on the freeway. Anyway, he has caged it, stripped it down and it is basically a track car now. 3- link rear with a panhard, coil overs, 340ci, auto, and around 3000lbs.
Re: The Ridge 4-12-13 [Re: 72Swinger] #1420285
04/15/13 05:39 PM
04/15/13 05:39 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Yeah, I have been slowly making my way towards this issue. I had, at one point, installed Schumacher mounts in the car. But that was entirely too much vibration and noise transferring into the car for everyday use. They were in there for about an hour. Currently run the Magnum mounts from Mancini.
I will see if I can come up with something is removable and can be used just for track days.
Re: The Ridge 4-12-13 [Re: amxautox] #1420286
04/15/13 06:25 PM
04/15/13 06:25 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I've used those in the past. One of them ended up tweaking those tabs but it never failed.
- Stu Harmon
Re: The Ridge 4-12-13 [Re: Viol8r] #1420287
04/16/13 06:46 AM
04/16/13 06:46 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Very nice
...your right side collector is showing...
There is another thread on here about the requirement of 2 schumaker torque rods, one on the right and one on the left to keep the motor mounts from being expanded and compressed and keeping the exhaust system in line
The motor compresses the right side and pushes the collector down, tearing the exhaust hangers...
I hope i do not need to explain further
Same problem in the 2011 pic posted...in 2012 we ran with 2 torque rods with no problems. Actually we noticed a difference in the car with the the 2 torque rods.
Re: The Ridge 4-12-13 [Re: ThermoQuad] #1420288
04/16/13 09:37 AM
04/16/13 09:37 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Looks great Marty. Now get rid of the automatic!
Re: The Ridge 4-12-13 [Re: Viol8r] #1420289
04/16/13 10:51 AM
04/16/13 10:51 AM
Santa Fe Springs, CA
Dan@Hotchkis Offline
Car looks fantastic! Hope to see you around later this year!
Re: The Ridge 4-12-13 [Re: BergmanAutoCraft] #1420290
04/16/13 12:14 PM
04/16/13 12:14 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Where were you when I spend $3k on a Gear Vendors??!! I am in deep now....probably something I will have to think about changing down the road.
We are attempting to secure a 6.4 with related drivetrain......Still will be a while before that gets swapped in.
Re: The Ridge 4-12-13 [Re: Dan@Hotchkis] #1420291
04/16/13 12:16 PM
04/16/13 12:16 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
We are thinking Silver State Classic.....Are you bringing the RRunner?
