If you have reason to believe it is a stock cam it could be a 68 only stick cam. (it would need to be an early 68 motor, measure the lift and that will tell the story). If it is an aftermarket cam you would need to pull it and hope there is a manufacturer number on it and try to look it up.
The best thing may be to measure the duration at .050 and lift for int and ex, then lobe sep, and you can decide if it would suit your needs.
From the looks of things I would consider a refresh/rebuild and new cam.
