72 Charger 340 engine mounting dilemma #1419692
04/14/13 10:08 AM
04/14/13 10:08 AM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
My dad has been finishing his 72 charger 340 car,
Today when trying to get the engine in, he discovered that with the Trans (727) installed the engine is about 1 1/2" to far forward to hit the k member mounting holes.
It's a 340 car 340 engine 340 motor mounts. What am I missing
Re: 72 Charger 340 engine mounting dilemma [Re: joshking440] #1419693
04/14/13 10:31 AM
04/14/13 10:31 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Is the transmission mount an original? Is it installed properly?
Re: 72 Charger 340 engine mounting dilemma [Re: ScottSmith_Harms] #1419694
04/14/13 10:33 AM
04/14/13 10:33 AM
SW Michigan
directcon Offline
directcon  Offline
SW Michigan
Yes it is original and drive shaft pits properly.
Re: 72 Charger 340 engine mounting dilemma [Re: directcon] #1419695
04/14/13 10:42 AM
04/14/13 10:42 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm assuming it's the cars original K-member? Do both motor mounts come up short or just one side?
Re: 72 Charger 340 engine mounting dilemma [Re: directcon] #1419696
04/14/13 10:42 AM
04/14/13 10:42 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
340 engine mounting brackets installed on the rear of engine mounting pads of the block?
Re: 72 Charger 340 engine mounting dilemma [Re: Joesixpack] #1419697
04/14/13 10:44 AM
04/14/13 10:44 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
i would get the engine installed first on the k-frame,let the trans hang, then raise the trans up with the trans crossmember installed,should line right up
Re: 72 Charger 340 engine mounting dilemma [Re: Joesixpack] #1419698
04/14/13 10:45 AM
04/14/13 10:45 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
ok are you installing the engine&trans as a combo,all ready bolted to gether?
Re: 72 Charger 340 engine mounting dilemma [Re: Joesixpack] #1419699
04/14/13 10:47 AM
04/14/13 10:47 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
is the trans allready in the car? your dropping in the engine from the top/and then mate them together?
Re: 72 Charger 340 engine mounting dilemma [Re: Joesixpack] #1419700
04/14/13 10:58 AM
04/14/13 10:58 AM
SW Michigan
directcon Offline
directcon  Offline
SW Michigan
I first installed motor then installed transmission, realized transmission mount was to far forward and driveshaft was too long. Then I removed motor mounts installed tranny mount drive shaft not fits, linkage for floor shifter now lines up but the front plate of motor mounts are about halfway between bosses on block? I didnt tear this car apart but trying to put back together. Thanks for all your help.
Re: 72 Charger 340 engine mounting dilemma [Re: directcon] #1419701
04/14/13 11:06 AM
04/14/13 11:06 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
#1. Since you didn't take it appart, are you 100% sure that you have the correct 340 engine mounts?
#2. Are you sure the mounts are on the correct sides of the engine and attached in the correct location (front or rear of the engine bosses, etc. as Joe asked)
#3. The drive shaft will have some slop in it due to the input shaft slip allowance and can be decieving, I'd leave it out until the engine and trans are installed properly
#4. Have another look at the trans mount to be sure it's installed correctly
#5. I'd bolt the trans and engine together, be sure the converter is installed all the way in, bolt it all up, and install it as a unit (even if it's a PIA).
Re: 72 Charger 340 engine mounting dilemma [Re: ScottSmith_Harms] #1419702
04/14/13 11:18 AM
04/14/13 11:18 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
CORRECT 340 B-BODY ENGINE MOUNTING BRACKETS. NARROW MOUNT IS DRIVERS SIDE
Re: 72 Charger 340 engine mounting dilemma [Re: Joesixpack] #1419703
04/14/13 11:25 AM
04/14/13 11:25 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
eliminate possibilities first.
bolt correct engine mounts correctly to engine block.
mate trans to engine
install if possible as 1 unit.drop engine unto k-frame with saddle rubber motor mounts(should have locater pin or boss protruding from lower part of mount),engine&trans should pivot up and down at trans to engage trans crossmember to alingment holes in body frame.(with crossmember bolted to trans.
use a long punch or drift to then aling rubber motor mount to k-frame holes,install two long rubber motor mount to k-frame bolts,install 4 long trans crossmember bolts,then your engine7trans is in place, then trial fit driveshaft by inserting splined front slip yolk till it stops,slide rearward to engage u-joint cross to rear axle yolk saddles.
Re: 72 Charger 340 engine mounting dilemma [Re: Joesixpack] #1419704
04/14/13 11:28 AM
04/14/13 11:28 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
alignment pins on lower section of rubber motor mounts,these engage hole in k-frame.
Re: 72 Charger 340 engine mounting dilemma [Re: Joesixpack] #1419705
04/14/13 11:31 AM
04/14/13 11:31 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
A-body 340 drivers side....if you got one of these on your 340 it will screw you up putting it in a B-body....
Re: 72 Charger 340 engine mounting dilemma [Re: Joesixpack] #1419706
04/14/13 11:35 AM
04/14/13 11:35 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
the trans mount is reversable. If you take it out off the cross member , it can be turned around. It does give around an inch difference or more. I have seen done by many installing it in the wrong position, causing the mounting holes to the trans to not line up. Just a suggestion for you to look at. The K menber as well as the trans cross memeber are engineered in from the factory, so it has to be a bracket incorrect issue only.
Re: 72 Charger 340 engine mounting dilemma [Re: Mopar-Al] #1419707
04/14/13 11:37 AM
04/14/13 11:37 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
340-360 drivers side bracket correctly installed
Re: 72 Charger 340 engine mounting dilemma [Re: Joesixpack] #1419708
04/14/13 11:40 AM
04/14/13 11:40 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
B/E 340-360 narrow drivers side engine mounting bracket
Re: 72 Charger 340 engine mounting dilemma [Re: ScottSmith_Harms] #1419709
04/14/13 11:40 AM
04/14/13 11:40 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yep! Hence my first comment
Re: 72 Charger 340 engine mounting dilemma [Re: Joesixpack] #1419710
04/14/13 11:41 AM
04/14/13 11:41 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
if all else fails consume mass quantities of this
Re: 72 Charger 340 engine mounting dilemma [Re: Joesixpack] #1419711
04/14/13 11:45 AM
04/14/13 11:45 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Best idea yet!
