450 GPH mechanical fuel pump #1418539
04/12/13 01:00 AM
04/12/13 01:00 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
Has anyone tried this pump from race pumps? How'd it work out?
http://www.summitracing.com/parts/RPU-2000
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 450 GPH mechanical fuel pump [Re: Hemi_Joel] #1418540
04/12/13 01:28 AM
04/12/13 01:28 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Read Vizard's remarks on calculating fuel pump capacity.
Boffin Emeritus
Re: 450 GPH mechanical fuel pump [Re: polyspheric] #1418541
04/12/13 09:43 AM
04/12/13 09:43 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Where can I read those remarks?
Old Geezer Racing
Re: 450 GPH mechanical fuel pump [Re: Hemi_Joel] #1418542
04/12/13 10:08 AM
04/12/13 10:08 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
My bro has one on his 517 Hemi. Built for pump gas & with the
cr*p, ethanol laced gas around the Reno area, it still vapor locked
on its maiden voyage. Installed a small 35gph electric helper pump
& it cures vapor lock on hot days in Vegas. The Race pump is pretty
trick, lightweight & seems to put out enought to get the heavy Charger to 114 mph at MATS. I think its arm pressure on the cam is really low, something like 35lbs, vs the 100lbs + that the Carters or Eddy mechanical pumps require? He still intends to switch to a 150 gph
Holley gerator pump to prevent vapor lock issues.
Re: 450 GPH mechanical fuel pump [Re: Triggerfish] #1418543
04/12/13 10:13 AM
04/12/13 10:13 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Holley gerator pump to prevent vapor lock issues. [/quo
Sounds like a nice ride. But I have always been told never put 2 pumps on one line. They acually work against each other.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: 450 GPH mechanical fuel pump [Re: Triggerfish] #1418544
04/12/13 10:24 AM
04/12/13 10:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Any pump that has a suction side thats mounted up
on the engine(in the heated area) will/can vapor
lock... thats why a pump mounted at the rear and
pressurizes the fuel going to the front doesnt have
the vapor lock issue(higher the pressure the less
it has the chance to vapor lock)
Re: 450 GPH mechanical fuel pump [Re: MR_P_BODY] #1418545
04/14/13 11:54 AM
04/14/13 11:54 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
That's why we're replacing the mechanical race pump with a Holley
gerator style pump & mounting it in the rear. Small electrical pump it has now is only turned on when starting or in traffic on a hot day.
I put the stock vapor separator setup on my 434 Hemi as the Shaker held all the heat around the fuel lines on my Challenger. When fuel pump pushrod lobe failed on the cam, I put the Holley pump in the rear & no more vapor lock. Good thing about the mechanical Race Pump is, IIRC, very low pressure on the pushrod.
Re: 450 GPH mechanical fuel pump [Re: Triggerfish] #1418546
04/14/13 12:50 PM
04/14/13 12:50 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I put this pump on my 572 Hemi, there are lots of reports of the pump losing prime if the fuel system is not absolutely perfect and leak free. They produced a priming kit that runs an electric pump and has a check valve because it won't prime it self. I put a comp cams brass tiped pushrod in and it has a small tick. With the correct regulator, I think these are great. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 450 GPH mechanical fuel pump [Re: astjp2] #1418547
04/14/13 06:19 PM
04/14/13 06:19 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Everything I have read about the race pumps say that they will vapor lock unless you run a return line.
Re: 450 GPH mechanical fuel pump [Re: Darryls-Demon] #1418548
04/15/13 01:28 AM
04/15/13 01:28 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
We have a 1/2" fuel line & a 1/4" return line & 2 Eddy 650's on the Hemi. The small 35 gph electric works great for priming when starting & puts out just enough pressure to prevent vapor lock on hot days, but I don't know if I'd trust it in heavy traffic on a 105 degree day.
Re: 450 GPH mechanical fuel pump [Re: Triggerfish] #1418549
05/09/13 12:22 PM
05/09/13 12:22 PM
Nowhere, USA
O
OUTLAW MOPAR Offline
O
Nowhere, USA
Should have my small block race pump today and will start plumbing the system this weekend. Will try summit fuel check valve before the pump and hopefully won't have priming issues
