Big Block fuel pump selection...
#1418081
04/11/13 03:41 AM
04/11/13 03:41 AM
Posts: 120 Vancouver,Canada
70 Roadrunner*
Vancouver,Canada
I'm just putting the wraps on re-building my 383 and am wanting to replace the old fuel pump while it's easily accessible.Should I go with a high volume fuel pump or find one similar to the stock item?It's a mild build...400-425 hp when it's all together,nothing too much...opinions would be great
Re: Big Block fuel pump selection...
[Re: 70 Roadrunner*]
#1418083
04/11/13 04:48 AM
04/11/13 04:48 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Go with the big pump, it will save you a lot of headaches if the stock pump is inadequate and causes the carb to go lean. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1418084
04/11/13 06:33 AM
04/11/13 06:33 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
We run Holley pumps.I agree spend a bit more and be sure.Rocky
Chrysler Firepower
[Re: mickm]
#1418088
04/11/13 05:46 PM
04/11/13 05:46 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
I bought the Mancini Carter pump for the Hemi and it seems to work great. Im running Dual Carter AFB competition series carbs 625's It's on there overstock sale for $79.95.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
