Mech. fuel pump w/ roller cam...who's done it? #1417820
04/10/13 05:05 PM
04/10/13 05:05 PM
an8sec70cuda Offline OP
Have any of you run a mechanical fuel pump w/ a roller cam in a big block or hemi?
How does the bronze tipped fuel pump pushrod hold up?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mech. fuel pump w/ roller cam...who's done it? [Re: an8sec70cuda] #1417821
04/10/13 05:10 PM
04/10/13 05:10 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I have. I got about 3 years out of my first one before it wore about .030". It depends on how heavy a spring is in the pump. I'm running an Edelbrock pump which I think is a 130GPH pump
Re: Mech. fuel pump w/ roller cam...who's done it? [Re: an8sec70cuda] #1417822
04/10/13 05:13 PM
04/10/13 05:13 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Im not running a roller but I have a Mech Pump on my Hemi.
I understand the distributor gear drive being bronze but why would there be a problem with the fuel Pump drive rod Roller or not?
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Mech. fuel pump w/ roller cam...who's done it? [Re: BB65Barracuda] #1417823
04/10/13 05:21 PM
04/10/13 05:21 PM
The factory pushrod will get chewed up by the billet cam...just like the dist. drive gear.
CHIP
Re: Mech. fuel pump w/ roller cam...who's done it? [Re: BB65Barracuda] #1417824
04/10/13 05:22 PM
04/10/13 05:22 PM
Jamey Offline
Jamey  Offline
I did. Notice past tense. I had a bronze tip push rod mushroom out and switched to an electric. I haven't thought twice about switching back.
Re: Mech. fuel pump w/ roller cam...who's done it? [Re: Jamey] #1417825
04/10/13 06:01 PM
04/10/13 06:01 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
I built a 499 a few years ago that goes to every cruise in within 50 miles of the house for a guy and it has worked fine for him Chip. Only time I have ever done that kind of setup but he has had no problems I am aware of.
One day I will have something cool here.
Re: Mech. fuel pump w/ roller cam...who's done it? [Re: sdaurity] #1417826
04/10/13 09:26 PM
04/10/13 09:26 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Ive done it a couple of times with the bronze rod. Worked ok with a carter hemi pump. Truth told I didnt put a ton of miles on it, but never had any issues.
MB
