Building a 438 stroker, what heads would you run? #1417661
04/10/13 08:59 AM
04/10/13 08:59 AM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
I'm building a 440 source 431=a .030 over 383 with a 3.75 stroke crank and 6.76 rods. Flat top pistons, Edelbrock performer RPM intake and 1411 750 carb, Isky hyd. cam .465 lift and .280 dur. and its going in a 727 shifted 71 cuda. 3.23 gears and an 3000 stall 11" converter. MSD ignition and headers.
I'm looking for the best bang for the buck along with longevity, and low maintenance.
What do you think of the Stealth heads? Or what else would you run for heads on this combo and still run pump gas?
thanks Moparts!!!
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: Building a 438 stroker, what heads would you run? [Re: mopar_leaner] #1417662
04/10/13 09:24 AM
04/10/13 09:24 AM
I'm building a 440 source 438=a .030 over 383 with a 3.75 stroke crank and 6.76 rods. Flat top pistons, Edelbrock performer RPM intake and 1411 750 carb, Isky hyd. cam .465 lift and .280 dur. and its going in a 727 shifted 71 cuda. 3.23 gears and an 3000 stall 11" converter. MSD ignition and headers.
thanks Moparts!!!
I assembled, built, a 383 last year for a local bracket racer and he decided to use the Stealth heads, you should check them over for quality, if you can't check them have a decent shop like Southward Machine check them over for valve guide to valve fit and look at the valve job The last thing is to make sure what compression ratio you end up with, I wouldn't want to have any more than 10.5 to 1 actual mechanical, not the dynamic , ratio If you haven't already bought all the pieces and you aren't in love with using the stock stroke from that 440 crank you can have it ofset ground to 2.200 rod size and have it offset stroked to 3.90 or 3.91, it can vary .010 depending on your core size now and the actual stroke locations. You will end up with some more C.I. and torque I have several 440 and one 400 built that way, they flat rock, especially on Oregon non ethanol gas pump I used a 6.700 long H beam BB Chevy style rod on the low deck and a set of Diamond custom pistons, I'm a delaer for Diamond products so PM me if you want a price ona set of them
Re: Building a 438 stroker, what heads would you run? [Re: Cab_Burge] #1417663
04/10/13 10:50 AM
04/10/13 10:50 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I have a 438 as well. I used box stock edelbrock heads. cam was comp's XE275HL, which was .525 lift, and (going from memory) around 230° @ .050" valve lift with the 1.5 ratio rocker arms.
engine made 535 tq and 505 hp on an engine dyno.
if I had it to do over again, I would seriously consider the stealths with a port job and set up by a pro. by the time you do that, you'll be a few hundred more than the box stock edelbrocks, but you'll have a MUCH better end product. when I did mine 6 years ago, my machine shop said that Edelbrock had fixed their quality control issues, and the heads were good to go out of the box now, that they've checked many of them over and haven't found any problems.
however, just last winter I put together a 5.9 magnum with magnum RPM heads, and one of the intake valves had such a poor valve job, I could see daylight through it and it had to go in for a correction valve job, so even "made in the US quality" isn't all that great, and needs to be checked over as well.
**Photobucket sucks**
Re: Building a 438 stroker, what heads would you run? [Re: 70Cuda383] #1417664
04/10/13 11:43 AM
04/10/13 11:43 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I think its actually 431 cubes as .060 over is a 438 I believe. Myself for what your doing the Stealth heads should be fine. Ron
Re: Building a 438 stroker, what heads would you run? [Re: 383man] #1417665
04/10/13 11:46 AM
04/10/13 11:46 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Yes. .030 is 431. .060 is 438
Mine is .060 over
Re: Building a 438 stroker, what heads would you run? [Re: 70Cuda383] #1417666
04/10/13 02:50 PM
04/10/13 02:50 PM
gregsdart Offline
gregsdart  Offline
Any of the small port heads will work fine. The cam isn't big enough to gain much beyond a basic bowl porting, so the work needed to get the best out of them isn't a lot of $$. I would be tempted to look for a set of used heads that will fit future plans, if you have any itch to go faster in the future.
Re: Building a 438 stroker, what heads would you run? [Re: mopar_leaner] #1417667
04/10/13 06:54 PM
04/10/13 06:54 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'd use the Stealth heads without any question.I only wish I had ported mine a bit,but maybe on the next build.
Nautilus Racing-
Re: Building a 438 stroker, what heads would you run? [Re: Chris2581] #1417668
04/10/13 08:47 PM
04/10/13 08:47 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Mopar leaner,
for your build the stock stealths will be fine , just be worth going through them to check all .
I have some pocket ported stealths on my 440 they have worked great . I am looking to move up to the CNC stealths later this year more flow , these should be fine for most any build up to 600HP which is all i am looking for plus they should be enough for a stroker if i go that route . Even this will be more than i need for my class racing.
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
