312 and 902 heads...what's the difference??? #1415063
04/06/13 01:56 AM
04/06/13 01:56 AM
Vancouver,Canada
70 Roadrunner* Offline OP
Vancouver,Canada
Guys I'm wondering how similar 312 heads are compared to 902 heads and can they be run on the same engine? The 312 on one side and the 902 on the other?Identically prepped springs/valves...etc. Maybe someone can help me out...thanks
Re: 312 and 902 heads...what's the difference??? [Re: 70 Roadrunner*] #1415064
04/06/13 09:47 AM
04/06/13 09:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is a 312 head ???
Re: 312 and 902 heads...what's the difference??? [Re: 70 Roadrunner*] #1415065
04/06/13 09:52 AM
04/06/13 09:52 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: 312 and 902 heads...what's the difference??? [Re: Dodgem] #1415066
04/06/13 10:57 AM
04/06/13 10:57 AM
Vancouver,Canada
Vancouver,Canada
Ok you know you've been in the garage for too long when this sort of stuff happens.I got the numbers ass-backwards...the heads in question are 3751213 and 3769902...the 902 heads are from a 1974 400/440 and the 213 heads are from a 1973 400/440 motor home...(shaking my head at yet another mess-up)...thanks
Re: 312 and 902 heads...what's the difference??? [Re: 70 Roadrunner*] #1415067
04/06/13 12:21 PM
04/06/13 12:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
vertually the same head will not make a difference to the motor.
Re: 312 and 902 heads...what's the difference??? [Re: Dodgem] #1415068
04/06/13 03:28 PM
04/06/13 03:28 PM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
213 heads have extra cooling holes from block to head
Re: 312 and 902 heads...what's the difference??? [Re: d-150] #1415069
04/06/13 05:05 PM
04/06/13 05:05 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Also some 213's and some 452 heads use tapered seat spark plugs and will also have to extra cooling holes as mentioned above. These are usually found on 440-3 engines.
Re: 312 and 902 heads...what's the difference??? [Re: 446acuda] #1415070
04/08/13 02:25 AM
04/08/13 02:25 AM
Vancouver,Canada
Vancouver,Canada
Guys thanks for answering my questions...they both are for 400/440 plants so I should be ok I guess...what the hell,I'm learning!
Re: 312 and 902 heads...what's the difference??? [Re: 70 Roadrunner*] #1415071
04/08/13 12:43 PM
04/08/13 12:43 PM
dogdays Offline
dogdays  Offline
Just use the heads, they will both respond to porting, even the MP porting templates will help.
I have a pair of 213 heads from a Newport 2-barrel 400 and THEY DO NOT HAVE THE EXTRA COOLING HOLES. And they take regular spark plugs. I'd probably prefer that they used the peanut plugs, as those 3/8" reach gasketed plugs are not hanging on the wall at WalMart any more.
As with everything else Mopar, never say never.
R.
Re: 312 and 902 heads...what's the difference??? [Re: 70 Roadrunner*] #1415072
04/08/13 07:49 PM
04/08/13 07:49 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
My 383 RR is like that; 213 on one side and 902 on the other. I pulled those heads off a 400 truck in a junkyard because that's what I could get to replace 906s.
Mine has been like that(213/902)since 1995 or so and I have no plans to take them off. There are no extra holes or special plugs or anything.
68 Roadrunner. 383 4-spd. Beat up.
