Good sealing VC gasket
#1414910
04/05/13 03:13 PM
04/05/13 03:13 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
What is a good sealing VC gasket for stock heads with MP cast alum valve covers?
EDIT!!
Let me add that I am looking for gaskets that will take a few valve lash checks and not leak after one or 2 removals.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Good sealing VC gasket
[Re: Von]
#1414911
04/05/13 03:37 PM
04/05/13 03:37 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Mr Gasket Ultras.My kid runs them on his 62 300 with the MP covers.Been on for 4 years now.No problems.I run them also and have had them off a few times.Still seal.Run them on the SBs also.Rocky
Chrysler Firepower
[Re: tboomer]
#1414913
04/05/13 06:01 PM
04/05/13 06:01 PM
Von
NE Oklahoma
Why not support a site sponsor? http://www.superformanceproducts.com/
Per Greg, they wont work with stock heads with a stock unmachined gasket rail.
[Re: Von]
#1414915
04/05/13 06:08 PM
04/05/13 06:08 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Are we talking a BB or a SB? The Mopar silicone embossed SB gaskets are excellent, a little pricey but I use these things for years and check valve lash about 6 times a year. More if I have problems. I don't know if they make that style for a BB though, I've never seen them.
[Re: Von]
#1414916
04/05/13 06:44 PM
04/05/13 06:44 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Ok I ran the eddy/mopar heads and cast covers for years. Nothing work very well. I try about all of them.I just use old cork gaskets glue them to the covers good for 3-4 times . replace them again. Best thing I every did was buy other set of covers. I know that.s not what you want to hear...
[Re: VernMotor]
#1414917
04/05/13 08:28 PM
04/05/13 08:28 PM
Von
NE Oklahoma
Honestly, I'll buy another set of VCs...if that is what it takes.
[Re: VernMotor]
#1414920
04/06/13 12:24 AM
04/06/13 12:24 AM
Von
NE Oklahoma
These are what I bought. Very nice for the money. I am very happy with them.
http://www.summitracing.com/parts/sum-440350/media/images/make/dodge
You should know that carb also LOL
I was gonna mention that is a great lookin carb!!!
BTW, I notice a 50 cc pump on front. Did that help you?
[Re: dOc !]
#1414922
04/06/13 09:32 AM
04/06/13 09:32 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Von is correct that our current line of valve cover gaskets are not designed for OEM cylinder head surfaces. Only aftermarket heads that have been machined flat & true on the valve cover rail. With that said..... our mopars are at a real disadvantage when it comes to sealing the valve cover because of how bad the casting is on the gasket rail of the cylinder head. Not to mention the close proximity of the exhaust manifold and the high heat generated from it so close to the gasket. I recently spoke with an engine builder who had to remove .070" off the valve cover rail of the head just to get a flat surface I'll assume not all heads need this large amount removed and sure some need minimal amounts of material removed. The issue with cork & rubber gaskets is they take a set (compression set) and need constant re-torquing to maintain a load on the fastener. Von if you have the heads off you can have the gasket rail milled flat. This will be an advantage with ANY gasket you may use. I'm in the process of evaluating new materials to address this common problem and will be testing samples soon on my Charger. Once I have some initial testing done I may put some out in the field for testing to get a review of others results
