Good sealing VC gasket #1414910
04/05/13 03:13 PM
04/05/13 03:13 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
What is a good sealing VC gasket for stock heads with MP cast alum valve covers?
EDIT!!
Let me add that I am looking for gaskets that will take a few valve lash checks and not leak after one or 2 removals.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Good sealing VC gasket [Re: Von] #1414911
04/05/13 03:37 PM
04/05/13 03:37 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mr Gasket Ultras.My kid runs them on his 62 300 with the MP covers.Been on for 4 years now.No problems.I run them also and have had them off a few times.Still seal.Run them on the SBs also.Rocky
Chrysler Firepower
Re: Good sealing VC gasket [Re: Von] #1414912
04/05/13 05:51 PM
04/05/13 05:51 PM
tboomer Offline
tboomer  Offline
Why not support a site sponsor?
http://www.superformanceproducts.com/
Re: Good sealing VC gasket [Re: tboomer] #1414913
04/05/13 06:01 PM
04/05/13 06:01 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Per Greg, they wont work with stock heads with a stock unmachined gasket rail.
Re: Good sealing VC gasket [Re: Von] #1414914
04/05/13 06:06 PM
04/05/13 06:06 PM
tboomer Offline
tboomer  Offline
Ok...Just trying to help..
Re: Good sealing VC gasket [Re: Von] #1414915
04/05/13 06:08 PM
04/05/13 06:08 PM
Guitar Jones Offline
Are we talking a BB or a SB? The Mopar silicone embossed SB gaskets are excellent, a little pricey but I use these things for years and check valve lash about 6 times a year. More if I have problems. I don't know if they make that style for a BB though, I've never seen them.
Re: Good sealing VC gasket [Re: Von] #1414916
04/05/13 06:44 PM
04/05/13 06:44 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Ok I ran the eddy/mopar heads and cast covers for years. Nothing work very well. I try about all of them.I just use old cork gaskets glue them to the covers good for 3-4 times . replace them again. Best thing I every did was buy other set of covers.
I know that.s not what you want to hear...
Re: Good sealing VC gasket [Re: VernMotor] #1414917
04/05/13 08:28 PM
04/05/13 08:28 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Honestly, I'll buy another set of VCs...if that is what it takes.
Re: Good sealing VC gasket [Re: Von] #1414918
04/05/13 09:05 PM
04/05/13 09:05 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
These are what I bought. Very nice for the money. I am very happy with them.
http://www.summitracing.com/parts/sum-440350/media/images/make/dodge
You should know that carb also LOL
Re: Good sealing VC gasket [Re: Von] #1414919
04/05/13 09:11 PM
04/05/13 09:11 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I just used a set of these Moroso rubber/steel core blue
gaskets under my vintage Mickey Thompson covers & they work
great. No leaks. Here's the Summit link
http://www.summitracing.com/parts/mor-93055/overview/make/dodge
Re: Good sealing VC gasket [Re: VernMotor] #1414920
04/06/13 12:24 AM
04/06/13 12:24 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
I was gonna mention that is a great lookin carb!!!
BTW, I notice a 50 cc pump on front. Did that help you?
Re: Good sealing VC gasket [Re: Von] #1414921
04/06/13 12:42 AM
04/06/13 12:42 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
With a CAST alum VC ...anything should seal .... the killer of VCG's is OVERtightening .....
Re: Good sealing VC gasket [Re: BeEtLeJuIcE !] #1414922
04/06/13 09:32 AM
04/06/13 09:32 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Von is correct that our current line of valve cover gaskets are not designed for OEM cylinder head surfaces. Only aftermarket heads that have been machined flat & true on the valve cover rail.
With that said..... our mopars are at a real disadvantage when it comes to sealing the valve cover because of how bad the casting is on the gasket rail of the cylinder head. Not to mention the close proximity of the exhaust manifold and the high heat generated from it so close to the gasket.
I recently spoke with an engine builder who had to remove .070" off the valve cover rail of the head just to get a flat surface I'll assume not all heads need this large amount removed and sure some need minimal amounts of material removed.
The issue with cork & rubber gaskets is they take a set (compression set) and need constant re-torquing to maintain a load on the fastener.
Von if you have the heads off you can have the gasket rail milled flat. This will be an advantage with ANY gasket you may use.
I'm in the process of evaluating new materials to address this common problem and will be testing samples soon on my Charger. Once I have some initial testing done I may put some out in the field for testing to get a review of others results
