Re: Rocker arm geometry on a 440
[Re: skrews]
#1414013
04/02/13 11:24 PM
04/02/13 11:24 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Are the contact patterns shown in the pictures of a full sweep on the cam lobe?
[Re: gregsdart]
#1414019
04/03/13 11:00 AM
04/03/13 11:00 AM
Posts: 75,059 U.S.S.A.
JohnRR
U.S.S.A.
shim up the shaft. that will move the scrub pattern more towards the center.
I don't agree with that. The rocker shaft bolt is not parallel with the intake valve, it is inclined towards it. The higher you move the rocker shaft, the closer the rocker and valve tip get, and the further out the scrub pattern will be, given you are going in the right direction to get the proper rocker arm to valve angle. The first thing to do is to figure out at what angle the rocker is to the valve stem right now.
I never looked at the hold down bolt to valve angle relationship, if this is the case then shimming the shaft up would move the shaft towards the valve.
Lash caps would be the easier way to do do it , the OP will need to change his valve locks because those are the kind that accept lash caps. Otherwise it's machining off, or machining of, the stands .
[Re: JohnRR]
#1414020
04/03/13 12:48 PM
04/03/13 12:48 PM
Posts: 1,318 Ohio
jlatessa
Ohio
I'm not sure that shimming will make it worse, take it to the extreme i.e. if you shimmed it an inch, the arc of the tip would be passing the valve on the inside, or is my reasoning wrong?? Joe
[Re: jlatessa]
#1414021
04/03/13 01:06 PM
04/03/13 01:06 PM
JohnRR
U.S.S.A.
Joe
that was my thought , but that was ASSuMEing the rocker shaft holdown pedestals were parallel to the valve stems , they angle toward the valves it seems, I don't have a head handy to confirm this.
